Condenser Fan Motor Old 3-wire To New 4-wire Help Needed - HVAC - DIY Chatroom Home Improvement Forum
Old 05-01-2013, 06:55 PM   #1
Condenser Fan Motor Old 3-wire to New 4-wire Help Needed
Hello, I have an A.O. Smith Condenser Motor and told this was the correct replacement. The old motor is 3-wire and the new motor is 4-wire. I have attached images. Can someone please explain which wires on the new motor go to the old connections.
This is an image of the Wiring Schematic on the old motor
http://www.screencast.com/t/9zhSsxG0nn
This is an image of the wiring schematic on the New Motor
http://www.screencast.com/t/Go3UmJLn
My question is where do the new 4 wires connect in relation to the old 3 wires. I was told the Brwn/White wire is not used. But I Want to confirm and also verify that BlK goes to Blk, Brwn to Brwn and Then Yellow to Purple? Please help. Thank you in advance
AnthonyCappa is offline   Reply With Quote
Old 05-01-2013, 07:57 PM   #2
biggles's Avatar
the connection is the 2 wires coming into the motor typical as is. forget the wires out of the motors old or new...brown-brown /white to cap others to the 2 incoming.different motor windings call for 2 separate cap brown wires as the new one has.rotation wires are changeable...air should blow up into your face looking down into the condenser..good luck
Old 05-01-2013, 11:40 PM   #3
Yeah, perhaps its just me, but I didnt understand your reply. I know where the current 3 wires connect, is it possible to tell me which of the new 4- wires would replace those 3 connections. I apologize for my ignorance, but to me, the simplest way to replace this is to take note of the current 3 colored connections and then if someone could state the color wires to replace them with and what to do with the 4th wire. Thank you in advance.
Old 05-02-2013, 05:40 AM   #4
An old Tradesmen
Rewards Points: 6,156
Use yellow for purple, and black is the same as the old black. Use the new motors brown wire the same as the old motors brown wire. Cap off the brown with white stripe wire.
Hopefully you got a new dual run capacitor also. When ever a PS motor(thats the type you have) is changed out, the capacitor should also be changed out.
Old 05-02-2013, 10:14 AM   #5
Thank you "Beenthere" That is fantastic and very clear. Your information also confirms with what I have read. I really appreciate your reply. Thank you again.
ground wire needed sirsparksalot Electrical 22 04-25-2012 10:59 AM
convert 3 wire range junction box to receptacle filby Electrical 0 06-05-2011 02:33 AM
water meter ground wire jumper not needed? windowguy Electrical 13 07-21-2009 06:37 PM
8 wire to 4 wire thermostat help needed dj petey Electrical 5 01-19-2008 10:11 AM
8 wire to 4 wire thermostat help needed dj petey HVAC 5 04-15-2006 01:20 PM
