Condenser Fan Motor Cross Reference Number - HVAC - DIY Chatroom Home Improvement Forum
Old 08-06-2012, 10:32 AM   #1
Condenser Fan Motor cross reference number
Hello,
Searching on the internet for a part number brought me here. I have an Amana RCC42A2E Prestige HVAC unit that needs the condenser fan motor replace. I can not seem to find the motor searching on google. I am guessing that the motor P/N is exclusive for Amana even though it is a GE part.
The motor I'm looking for is a GE 5KCP39JFS301AS. Is there a way to cross reference this part to another number or maybe find out if it has been superceded.
I'm also going to replace the capacitor and the contactor.
Pictures attached.
Thanks in advance.
Condenser Fan Motor cross reference number-fanmotor.jpg   Condenser Fan Motor cross reference number-cap.jpg   Condenser Fan Motor cross reference number-contactor.jpg
samaritano is offline   Reply With Quote
Old 08-06-2012, 10:43 AM   #2
Rewards Points: 13,690
Check on the W.W. Granger web site.
Old 08-06-2012, 12:05 PM   #3
Most likely the p/n on the motor is specific to the manufacturer.
You need a standard 240v 1/6 hp 825 RPM motor that draws 1.0 amps. It will NOT be an exact replacement (i.e. wire color for wire color) so be sure to take careful notes of how the old one is wired in now. Most of the new generic motors will be 4 wire, and yours is a 3 wire.
scottmcd9999 is offline   Reply With Quote
Old 08-06-2012, 01:07 PM   #4
I have found a replacement unit at Grainger but the shaft is 6.6" and I need 2.5". Also the ambient temp. rating is 40C and here in Texas is 40C everyday in the summer. I would think that that would shorten the life of the motor.
Old 08-06-2012, 01:21 PM   #5
Shaft size is not really important as long as it doesn't impact anything (like the top of the compressor, for example) you're okay. Most generic replacement motors have longer shafts so they'll fit a wider variety of applications. If needed, you can always cut the shaft down with a hacksaw (do this AFTER installing the blade).
Here's a motor that seems to fit your specs with a 60c ambient rating, whic puts it just over 140f. I think there are 70 and 80c motors, but I didn't check further.
http://www.grainger.com/Grainger/DAY...U93?Pid=search
Old 08-06-2012, 02:00 PM   #6
Thanks Scott for the link. I have now various options. Did not know that you could cut the shaft to make it fit.
How about this one. It has a load of .9 amps. Would that work? Or maybe this one.
http://www.grainger.com/Grainger/DAY...an-Motor-4M225
Old 08-06-2012, 02:21 PM   #7
Your link points to a "session expired" page on the Grainger site.
Old 08-06-2012, 08:50 PM   #8
Rewards Points: 150
Link should work now, Grainger was having site issues today.
TJ_in_IL is offline   Reply With Quote
Old 08-06-2012, 09:05 PM   #9
What does the letters in the red box stand for?
Old 08-07-2012, 05:48 AM   #10
The amp draw is high-ish on your motor - 1.3 @230v. You should try to install a motor where the amp draw is the same +/- 10% (i.e. between .9 and 1.1 amps). Note the one I linked to has slightly high amp draw as well, so you might continue looking around.
That's the Insulation Class of the motor. Your current is a B, which (according to the link below) is the most common class for 60 cycle motors in the US.
http://www.engineeringtoolbox.com/ne...ses-d_734.html
Old 08-07-2012, 10:23 AM   #11
biggles's Avatar
check here for motors http://bestbuyheatingandairconditioning.com/ definitly Grainger will match one slight HP change won't hurt low on those RPMs will make it a search though this is close with 1/4HP but that rotation keep that in mind when getting on...if it doesn't say cw-ccw on the new motor it isn't changeable! 10ths of amps won't hurt that contactor either being 1/4HP.the motors are general to all units like car parts are with different ratings and sizes and notlabels on the motor for Amana GE sells to all brands acording to there condenser specs with air moving and amp draws.
Old 08-07-2012, 09:42 PM   #12
Rewards Points: 150
you can also check out www.zorotools.com. They seem to have the best prices on Dayton products around.... even better than Grainger (http://zorotools.com/g/00032608/k-G1653434/)! And looks like they have a free shipping special going on right now, any size order. Getting my list together as we speak!
Old 08-08-2012, 06:17 AM   #13
Well, I ended up calling an HVAC technician. He replaced the motor with 1/8-1/3 HP motor and a matching capacitor. It is all working great.
Thank all for the help.
Old 08-09-2012, 03:57 PM   #14
Rewards Points: 77
Shaft length and specific direction is typically all that makes a motor ' OEM' these days
Filtration / HVAC & Indoor Air Quality Solutions
AirstarFilters is offline   Reply With Quote
Trane XL80 blower motor part number? keverino HVAC 17 01-10-2012 09:01 AM
Heat and Condenser running at same time emmark22 HVAC 2 01-12-2010 12:28 AM
Carrier ECM motor number pwrengineer HVAC 19 06-22-2009 01:21 PM
Set & Charge AC condenser tbroertjes HVAC 2 01-05-2009 05:19 PM
Number of receptacles and size of wires KUIPORNG Electrical 5 06-28-2006 01:21 PM
