Condenser Fan Motor And Capacitor Replacement - HVAC - DIY Chatroom Home Improvement Forum
Old 07-15-2012, 09:18 AM   #1
Question
Condenser fan motor and capacitor replacement
Tomorrow I have to buy and replace my condenser fan motor. Question is do I need to buy a new capacitor also. Present one is less than a year old. The tech who put it in convinced me to pay a lot of extra bucks for it but since then I am not sure I trust him. The system is a split setup Coleman inside and Armstrong SCU10E36A-1A condenser outside. Present fan is AN A O Smith F42C52A45. Plan on replacing it with an Armstong Ducane 42521-001 and an 89M77 cap if I need to. Prompt answers appreciated as I am only getting cold air now by oiling a nonoilable bearing???
topgun38 is offline   Reply With Quote
Old 07-15-2012, 09:23 AM   #2
AKA HVACTECHFW
Rewards Points: 1,208
yes, always replace the capacitor with a motor replacement
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
The Following User Says Thank You to hvactech126 For This Useful Post:
topgun38 (07-15-2012)
Old 07-16-2012, 09:03 PM   #3
Condenser is fixed. Local (60) miles one way had parts coolling now slowly, outside temp is 99. Mfg of old cap says I could have used it but I followed hvactech126 advice and replaced it. My new question is it any good to anyone or do I need to dispose of it in some special manner????
Old 07-16-2012, 09:23 PM   #4
An old Tradesmen
Rewards Points: 6,906
By replacing the cap when you put in the new motor, you did the right thing.
No special needs for disposal.
The Following User Says Thank You to beenthere For This Useful Post:
topgun38 (07-17-2012)
Old 07-18-2012, 12:38 AM   #5
shouldn't a used cap be discharged before being tossed?
allthumbsdiy is offline   Reply With Quote
Old 07-18-2012, 04:56 AM   #6
An old Tradesmen
If you want to run a screw driver across the terminals to discharge it, you can. By now it should already have dissipated its charge9since (7/15).
topgun38 (07-18-2012)
Any Issues: Old Condenser - New System? JulieMor HVAC 3 07-05-2012 07:57 PM
Condenser fan airflow direction?? nicksab HVAC 8 09-20-2011 09:24 PM
Carrier Condenser Unit Screwed? gimmes name HVAC 6 07-24-2011 07:05 AM
Goodman Fan Condenser Replacement Help bigjohnstud4200 HVAC 2 07-03-2010 01:54 PM
Condenser Fan Quits After approx 10 min kdogg HVAC 5 08-06-2008 06:03 PM
