Condenser Fan Motor Capacitor - HVAC - DIY Chatroom Home Improvement Forum
Old 06-15-2010, 05:25 PM   #1
condenser fan motor capacitor
replacing a condeser fan motor that the bearing are going out on( 16yr old unit), the new fan has 4 wires not the three from the old unit. I bought the capacitor for the new one when i purchaced the motor. Correct me if im wrong but the two brown leads go to each side of the capacitor( one on each terminal) and then the White and black go to the contacts where the old ones came off. then make sure the new capacitor is secured to the condenser housing. other than that nothing else needs to happen.
cas954 is offline   Reply With Quote
Old 06-15-2010, 06:03 PM   #2
that is correct
The Following User Says Thank You to Marty S. For This Useful Post:
cas954 (06-15-2010)
Old 06-15-2010, 06:10 PM   #3
Hvac Pro
yuri's Avatar
Rewards Points: 2,276
Perforated metal strap works well. Make sure the capacitor is in the weatherproof electrical box where the contactor is and not exposed to rain and attached to the motor etc. If it shorts out and some kid gets electrocuted you can be sued.
The Following User Says Thank You to yuri For This Useful Post:
cas954 (06-15-2010)
Residential AC Unit - Can a stalled condenser fan cause other problems? bcphoto HVAC 6 04-03-2010 10:09 AM
Condenser freezing zep HVAC 2 01-30-2010 08:04 PM
AC Condenser source of ignition? hrjrkr HVAC 4 09-16-2009 11:33 AM
Condenser Fan Quits After approx 10 min kdogg HVAC 5 08-06-2008 06:03 PM
Condenser fan motor/compressor kristeng HVAC 3 07-26-2008 11:02 AM
