Condenser Fan Cycling Switch Replacement - HVAC - DIY Chatroom Home Improvement Forum
Old 01-23-2010, 06:58 AM   #1
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
I have a Manitowoc ice machine that I need to replace the fan cycling switch. It's a Model BDO152A
The switch is soldered in. My questions are:
1) With the LLS closed, will the system pump down and allow me to remove the old and solder in the new one or will I still have pressure on the system? Of course, if the LLS doesn't leak. Any chance of contaminating the system?
2) If I do need to evacuate the system to replace this, can I just buy a klixon with the same temperature range and do it that way?
wirenut1110 is offline   Reply With Quote
Old 01-23-2010, 10:02 AM   #2
newtech's Avatar
Rewards Points: 164
1) With the LLS closed, will the system pump down and allow me to remove the old and solder in the new one or will I still have pressure on the system? Of course, if the LLS doesn't leak. Any chance of contaminating the system? I could not find the model number that you posted, but even if the LL solenoid valve is after the fan cycle control there will still be pressure on the system. If you check the low pressure control it is set to cut out at around 12 psi. And yes you will contaminate the system.
Yes you can go with a generic fan control as long as the ratings are the same,amps,voltage,pressures....
Like stated above I couldn't find the exact model, to do it the correct way, you need to evacuate the system. You could install an access stub with a schraeder core, that way if you need to change it again you will not have to pull the charge.
Make sure that you also change the LL Drier at the time of the repair, if it is POE oil a 500 micron vac or lower is critical. Make sure that you Weigh in the charge.
There is one other way that you could do it with-out pulling the charge. (not recommended) You could install a swivel tee to the high side access port(if you have one) and install your fan cycle control to it.
Manitowoc Service Manual B-Model
newtech is offline   Reply With Quote
Old 01-23-2010, 10:29 AM   #3
Rewards Points: 510
Thanks very much for your reply.
Different wiring on replacement dimmer switch kmmccorm Electrical 2 01-09-2010 07:48 PM
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 04:06 PM
4 way switch confusion Richo Electrical 10 04-09-2009 08:11 AM
Replacing a bathroom fan switch cmacjr22 Electrical 4 11-04-2008 07:14 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 02:19 AM
