Condenser Fan - Carrier Synergy 2000 - HVAC - DIY Chatroom Home Improvement Forum
Old 09-08-2011, 12:25 AM   #1
Condenser fan wants to spin, but it just sort of stops and starts and doesn't spin. I have two identical units, upstairs and down. Swapped out start and run cap from other unit, and didn't solve the problem. Fan motor is a 2-speed GE HC38GE221A. That looks like an ECM motor and direct replacement is not cheap.
Is there an inexpensive single speed motor I can substitute? If so, how should it be wired? OEM motor has black, brown and ground wires connected to filter and yellow and blue wires connected to PW1 and PW2 on a circuit board.
gnikoli is offline   Reply With Quote
Old 09-08-2011, 12:38 AM   #2
JJboy's Avatar
Swap the motor modules.
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 09-08-2011, 12:58 AM   #3
I'm Your Huckleberry
Rewards Points: 2,270
Two stge cooling means two stage fan. The fan is not the only thing with two speed, the compressor is as well. If you put a single stage fan on a two stage compressor then if you think the OEM condenser fan motor is expensive, wait unit that single stage fan takes out that two stage compressor.
Two car payments plus their insurance and a house note.
There are single stage condenser fan motors that are OEM only as well.
Doc Holliday is offline   Reply With Quote
Old 09-08-2011, 11:32 AM   #4
Original motor is not available, there is a replacement part number. Can't find a original replacement module, so looks like I have to buy a complete motor rather than module only even if I find that only the module is bad.
Old 09-08-2011, 01:34 PM   #5
After much more homework and the much appreciated replies, I understand that I am not just replacing a multi-speed motor and I have to replace with ECM motor. Original is a GE ECM 2.0 that is not made anymore. Motor tests okay according to GE service guide, so apparently, only the module needs to be replaced. Since ECM 2.0 is not made anymore, I understand what I need is a 2.3 replacement kit for the 2.0, however, I can't find a source for that kit. Are such kits sold to DIYers? If yes, any suggestions? Where can I get one? Or maybe I just need to bite the bullet and buy the whole assembly, which I understand to be the new Genteq 142R model.
Old 09-08-2011, 01:54 PM   #6
JJboy's Avatar
Try these websites.
Dealer/Contractor Site:
http://www.thedealertoolbox.com
http://www.evergreendealer.com
Consumer Site:
http://www.genteqcomfort.com
Old 09-08-2011, 03:19 PM   #7
I like www.americanhvacparts.com/
Good luck!
Ps ECM motors will not have a cap...make sure u don't need a PSC!
If you search a product number u should find an appropriate item...
Dr.HVAC is offline   Reply With Quote
Carrier a/c condenser fan motor still running slowly after thermostat is satisfied GetYourShineBox HVAC 18 06-14-2013 12:26 PM
Carrier Condenser Unit Screwed? gimmes name HVAC 6 07-24-2011 08:05 AM
Compare Carrier Model 25HNA936A003 versus Model 25HPA636 gchapman General DIY Discussions 0 11-02-2010 01:52 PM
Goodman Fan Condenser Replacement Help bigjohnstud4200 HVAC 2 07-03-2010 02:54 PM
