Condenser Air Temperature In - HVAC - DIY Chatroom Home Improvement Forum
Old 04-26-2013, 12:35 PM   #1
Rewards Points: 2,020
Something I've wondered is how much efficiency difference ( if any ) there is when let's say the condenser is in shade on a summer day with the ambient temperature for example 98F ( 36.6C ) vs the condenser being in a sunny location with the surrounding air temperature 118F ( 47.7C ). If there is a link to this subject where actual studies have been done I'd sure take a look at them and appreciate any information you have.
Old 04-26-2013, 01:56 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 380
not so much efficiency but energy usage is the issue which translates into $$ cost to run. freon pressure and work/NRG usage is directly proportional to temperature. higher temp=more work for the AC compressor to do to get rid of the heat. if you want to know about efficiency then google SEER and read up on it.
Old 04-26-2013, 02:18 PM   #3
Not so much interested in the seer at this point but when you say " higher temp=more work for the AC compressor to do to get rid of the heat " I'm trying to determine how much less / more work is required if the same condenser unit is located in the two different areas with all other elements being the same. ie same building, line set length, insulation level etc.
Old 04-26-2013, 03:36 PM   #4
Hvac Pro
yuri's Avatar
Rewards Points: 380
You need to be a mechanical engineer to figure that one out. Or a design engineer.
Old 04-26-2013, 05:47 PM   #5
An old Tradesmen
Rewards Points: 8,142
Less work is higher SEER.
It makes no real difference if your condenser is in a grass yard and the sun beating down on it or in a grass yard and in the shade. now if its on a roof, or surrounded by asphalt, it will make a difference. probably use 10% more electric, and lose 5 to 7 % of its capacity.
Old 04-26-2013, 06:06 PM   #6
Hvac Pro
yuri's Avatar
Rewards Points: 380
Yep, I have seen the same condensor run 25 psi higher head on R22 with 10 psi more suction just because it is 100F or more on that flat asphalt roof vs on the ground. With it being so hot in Texas and Arizona and the desert I wonder if they get vapor lock in the fuel line to the condensor like a car does??
Old 04-26-2013, 06:54 PM   #7
So if the air entering the condenser unit is 98 degrees and the air entering that same unit increases to 118 degrees, for what ever reason the temperature change, the efficiency is the same of the unit. Ok , got it.
Old 04-26-2013, 07:08 PM   #8
An old Tradesmen
No. 118 air entering the unit makes it less efficient. However 118 in the sun does not make it 118 air entering the unit. The air is still only 98.
The Following User Says Thank You to beenthere For This Useful Post:
ben's plumbing (04-26-2013)
Old 04-26-2013, 07:18 PM   #9
Hvac Pro
yuri's Avatar
Rewards Points: 380
efficiency is determined by how effective the compressor is/worn out valves or scrolls etc. just like a worn car motor. efficiency goes down with wear. the rest of it stays pretty much fixed as the coils stay the same size.
The Following User Says Thank You to yuri For This Useful Post:
Old 05-02-2013, 04:50 PM   #10
HVAC Tech
Jim-Martin's Avatar
A quick answer
Go to http://www.achrnews.com/articles/how...tem-efficiency
Dirty or blocked has the same effect as heat.
Have a nice day,
Jim Martin
Last edited by beenthere; 05-02-2013 at 07:08 PM. Reason: Removed link to company website in post
Jim-Martin is offline   Reply With Quote
Condensation on fiberglass window frame creamaster General DIY Discussions 11 01-05-2012 07:42 PM
caulking old wood windows andyman Windows and Doors 10 12-31-2011 03:39 PM
Condensation amyevans Windows and Doors 6 10-21-2011 10:11 PM
Moisture on windows baum Building & Construction 56 12-22-2009 05:39 PM
Sweating windows big daddy-o General DIY Discussions 15 01-06-2008 02:41 PM
