Condensation From Vents Under House In Crawl Space - HVAC - DIY Chatroom Home Improvement Forum
Old 09-02-2011, 09:07 AM   #1
Condensation from vents under house in crawl space
Our termite inspection revealed vent condensation under the house in the crawl space. They recommend a de-humidifier be installed under the house, along with sealing the vents. Cost is $3500. Does this solution sound right? Is there a less expensive method to solve the problem?
DIY Kathy is offline   Reply With Quote
Old 09-02-2011, 09:27 AM   #2
Retired from the grind
Rewards Points: 6,652
You do not need a dehumidifier, what you need, is to figure out why conditioned air is getting into the space. How many vents are there around the perimeter of the house for the crawlspace. As for the humidity level, what was it, along with temp under the house, compared to outside? Also, is there any material covering the dirt under the house, to help keep the moisture from the ground invading the space?
Crawls are always going to be cooler, because their dew point is lower, than it is outside, same for the temp.
Bad smell in crawl space. John_W General DIY Discussions 34 06-03-2014 12:57 PM
crawl space vapor barrier help Eddie Bear Building & Construction 8 07-04-2011 11:06 PM
Condensation in Crawl Space jobondur Building & Construction 1 07-06-2010 09:11 PM
Closed crawl space under house DeanPk Building & Construction 9 01-20-2010 10:43 AM
Crawl Space Insulation skinny2 Building & Construction 10 12-12-2008 11:36 AM
