Condensation Tube Water Turning House Yellow. - HVAC - DIY Chatroom Home Improvement Forum
Old 06-25-2011, 10:22 AM   #1
Condensation tube water turning house yellow.
Not super knowledgeable about this stuff but this is what I know:
I believe the a/c has a pipe in attic that leads to outside in middle if house. The water drips a lot on really hot days and a tech did a review of system when buying house in February...so I don't think anything is wrong with system, it's just doing it's job.
My problem is it runs down the siding onto shingles below it and us turning the siding and shingles yellow. It's about a 5ft diameter ywllow patch. So how can I redirect this water to the side of the house or somewhere other than on siding and shingles?
Thanks!
Ipty94 is offline   Reply With Quote
Old 06-25-2011, 10:33 AM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,842
Add to that pipe with some pvc pipe. May want to get a HVAC guy or plumber to do it as it will need securing to the house also.
Old 06-25-2011, 11:07 AM   #3
HVAC Tech/Owner
Rewards Points: 604
Are you sure that's not the emergency drain from the secondary pan? Take a look in your attic and make sure you cant see any water under the system
Technow is offline   Reply With Quote
Old 06-25-2011, 01:22 PM   #4
biggles's Avatar
as suggested just continue it down to the ground and elbow out brick under it and your good....might consider a secondary pan"OVER FLOW" under your air handler pipe it out over the kitchen window"america spends 75% of ther lives in the kitchen dripping over the window...drop the drink and run up to the attic....or your frront stoop.when that first pipe is banging the water out your home should be cool..never ever see water on that other pipe.1" pan under your air handler 4'x4' boocu water and as gravity goes it runs down the walls consider it...
Old 06-25-2011, 01:45 PM   #5
An old Tradesmen
Rewards Points: 6,906
Yep, make sure thats not the drain for your emergency pan.
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
No water in house dls6w4 Plumbing 10 02-12-2011 06:45 AM
low hot water pressure angus242 Plumbing 10 01-08-2009 11:41 AM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 07:32 AM
