Condensation On Suction Line - HVAC - DIY Chatroom Home Improvement Forum
Old 05-23-2009, 08:11 AM   #1
condensation on suction line
I have a 6 year old unit but the suction and high lines are about 20 years old and so is the insulation on them. The air conditioner is working very well except for condensation dripping from the suction line. Is it just a failure of the insulation or.......? The coils are clean. I was told the lines are leaking and had to be replaced but if this was true I don't think the unit would working as well as it is. Any thoughts.
SAMMY25 is offline   Reply With Quote
Old 05-23-2009, 08:16 AM   #2
Rewards Points: 29
When the unit is running, the suction line is below the dew point and therefore will sweat. I'd replace that insulation though, it's easy and cheap, you can get it at Lowes.
Dave Carney is offline   Reply With Quote
Old 05-23-2009, 09:00 AM   #3
An old Tradesmen
Rewards Points: 8,184
Probably just needs reinsulated.
Its fairly common for older insulation to deteriorate, and cause condensation to form from normal operation.
Old 05-23-2009, 01:08 PM   #4
yep
BEENTHERE got it.
When you where told the line set was leeking did the tech add freon or not?
Insulation is what you need.
Goodluck
texas115115 is offline   Reply With Quote
Old 05-23-2009, 03:11 PM   #5
biggles's Avatar
if you get the lenghts of armaflex tubing size it on the diameter of the copper so it is tight no air between it and the piping.on the elbows use the caulk insulation tape..it insulates and is tacky and is tight on those elbows
Old 05-23-2009, 06:55 PM   #6
if youre only talking about maybe the last foot of copper before the conderser i wouldnt "sweat" it no big deal if its only dripping on the ground
kennzz05 is offline   Reply With Quote
Old 05-26-2009, 11:17 AM   #7
Reinsulate the line, and find yourself a new pro that knows how to diagnose a leaking system.
dac122 is offline   Reply With Quote
Old 06-03-2012, 12:34 AM   #8
Rewards Points: 27
Good one dac122 a truck and some tools and they know it all.
nunesent is offline   Reply With Quote
Old 06-03-2012, 07:47 AM   #9
Rewards Points: 582
yep .....believe nothing you hear and only half of what you see...
Old 06-03-2012, 11:59 AM   #10
If it's free...It's me
Yep...Gas and Go...The contact number is only in service until the refrigerant tank runs out...it is amazing that they can get 50# of refrigerant out of a 30# tank...and without even using a scale.
It pays to know...even if you don't DIY. (...and it costs not to know.)
Johnny'sHotDogs is offline   Reply With Quote
Making nice tight bends in 1-1/8" Suction Line hennyh HVAC 8 10-28-2009 10:13 AM
ac suction line placement? nimbenja HVAC 8 10-28-2009 05:43 AM
electric line and gas line couch potatoe Electrical 17 09-30-2008 10:43 PM
suction line insulation? Lookin HVAC 8 06-06-2008 04:33 AM
