Condensation On Pipes - HVAC - DIY Chatroom Home Improvement Forum
Old 08-29-2008, 05:00 PM   #1
Condensation on pipes
Hello! Our AC is not running properly and I am hoping to get some help figuring out why. The unit is running, blowing air through the vents but it is not cooling the air. In addition, there is a good deal of condensation on the pipe running from the outside unit to the furnace. Any suggestions on how to fix this? Thanks!
teacherman513 is offline   Reply With Quote
Old 08-31-2008, 06:49 AM   #2
oops, did I do that!
You may have developed a refrigerant leak, and need to add gas. Which line is sweating, the larger or the smaller?
8 Ball is offline   Reply With Quote
Old 09-04-2008, 06:50 PM   #3
HVAC Sales
Your AC has two moving parts. One for moving air your (blower) the other is the compressor. Your blower is fine because you have airflow, call a tech and have them check out your refrigeration lines. Tell the tech your story and find out what brand your unit is before your call, it may speed it your replacement parts lead time.
Silent Bob is offline   Reply With Quote
Old 09-05-2008, 11:08 AM   #4
Rewards Points: 210
Funny, I've got the same similar problem.
My bigger overflow condensation line that runs outside is the one that is heavily condensating. It just started doing this and I've also noticed that the air handler is getting very cold to the touch on the outside of the unit. I've noticed condensation on the outside also. This has just started also.
imola ghost is offline   Reply With Quote
Old 09-05-2008, 12:55 PM   #5
Whatamess
If your drian line is sweating that is normal when the cold water hits hot air if it is humid outside.
I may go home hungry, but not tired and hungry.
TazinCR is offline   Reply With Quote
Old 09-05-2008, 01:11 PM   #6
Rewards Points: 210
But I've never seen it condensate like it has lately. Another thing is I can hear the refrigerant flowing thru the copper pipe, almost like its starving? I don't know how else to describe it but shouldn't it be almost quiet?
Drain Pipes, Walls and Studs mattaparity Plumbing 2 12-18-2011 08:22 AM
frozen pipes helper Plumbing 3 03-23-2008 01:35 PM
Sweating windows big daddy-o General DIY Discussions 15 01-06-2008 03:41 PM
Installation of new pipes on Water main... NJE Plumbing 3 02-05-2007 01:06 PM
