Condensation Pan Leaking - HVAC - DIY Chatroom Home Improvement Forum
Old 08-08-2009, 10:59 AM   #1
condensation pan leaking
i have a 10 year old Kenmore heat pump and it is leaking it does not look like the pan is overflowing. and i know the line is not blocked but i can't find the leak. it is leaking only when it is operating. any ideas or helpful hints?????????
dclx12 is offline   Reply With Quote
Old 08-08-2009, 02:29 PM   #2
JohnH1's Avatar
If the drain is not blocked then probly one of the following.
1st Eather the pan is rusted through,
2nd The coil is frozen and dripping but you would not have much cooling with this one if any.
3rd The coil is dirty and dripping
JohnH1 is offline   Reply With Quote
Old 08-09-2009, 07:06 PM   #3
CDH
Rewards Points: 29
i had the same thing happen the other day, except mine is a Carrier, I to thought that the line was'nt blocked as I had cut a T in it that I pour bleach in regularly, mine has a secondary drain hole just above the threaded one, long story short I cut my pvc drain to disassemble and when I unscrewed the threaded coupling out I found a big wad of algae had stopped it up partially right there prior to where I cut in the T so no bleach was getting there, I cleaned the coils and bleached out the pan and now it works like a champ, may not be your problem but thought it might be worth a look.
CDH is offline   Reply With Quote
Leaking Shower Faucet sprtnfan Plumbing 2 12-20-2008 11:08 AM
Sweating windows big daddy-o General DIY Discussions 15 01-06-2008 02:41 PM
Leaking PVC Pipe kennykenny Plumbing 8 12-26-2007 08:53 PM
condensation leaking in basement! geniedee HVAC 3 08-25-2006 07:58 PM
