Condensation On Metal A/C Vents.... - HVAC - DIY Chatroom Home Improvement Forum
Old 07-06-2009, 05:42 PM   #1
miamijohn's Avatar
Condensation on metal A/C vents....
Will replacing with plastic vents help? Along with checking all others reasons...
miamijohn is offline   Reply With Quote
Old 07-06-2009, 06:49 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,454
No. The plastic will get cold/to the dew point and sweat just like metal. They need to be insulated or have more air moving thru them so they are not so cold.
Old 07-06-2009, 11:03 PM   #3
miamijohn's Avatar
What do i insulate with?
What does....Have more air moving thru them so they're not so cold mean?
If more cold air were to move thru them wouldnt it get colder and sweat more? Im a little confused on this one. Thanks for your help!
Old 07-07-2009, 07:37 PM   #4
Hvac Pro
yuri's Avatar
Is the unit a horizontal type in an attic? The air temp coming off the cooling coil may be too low from a lack of airflow or too slow fan speed or dirty coil etc. If the air quantity is increased so does the load on the coil and the air temp rises which raises your vent temp above the dew/sweating point. Lots of those attic units use an insulated flex pipe which won't sweat. Metal pipe needs insulating.
Wire size for 300watt trans, 3 way 100ft Al the Diy guy Electrical 16 03-22-2008 09:46 PM
Condensation on Metal Window Frames: Should I Caulk? xquercus General DIY Discussions 6 06-29-2007 10:24 AM
