Condensation Issues - HVAC - DIY Chatroom Home Improvement Forum
Old 07-18-2012, 08:23 AM   #1
Rewards Points: 264
condensation issues
Got condensation on a grill. Room has drop ceiling acoustical tile.
Will it help to insulate the boot really well? If not, any suggestions?
7echo is offline   Reply With Quote
Old 07-18-2012, 08:36 AM   #2
Yes, you can insulate the boot, and that should be done. However, condensate at the grill face is often caused by low air flow. Check filters, evaporater coils, blower, etc etc to insure they're clean.
scottmcd9999 is offline   Reply With Quote
Old 07-18-2012, 10:23 AM   #3
Rewards Points: 610
also make sure you have adequate return air to promote air flow
condensation should only occur when system is first turned on then stop once room is cooled down and humidity is lowered
techpappy is offline   Reply With Quote
Old 07-18-2012, 01:33 PM   #4
biggles's Avatar
filter and squirrel cage are clean sounds like slow air rolling over the register....make sur fan is hi speed listen in cooling mode...then shut at stat and put to FAN/ON no cool call should be HI
Condensation on new vinyl windows jimleahman Windows and Doors 12 02-22-2012 02:17 PM
Really Condensation? Or is it a Leak? DTproject Plumbing 6 02-21-2011 08:01 PM
condensation issues - major toilet sweat wombosi HVAC 8 07-23-2010 01:42 PM
Moisture on windows baum Building & Construction 56 12-22-2009 06:39 PM
Sweating windows big daddy-o General DIY Discussions 15 01-06-2008 03:41 PM
