-   -   condensation issues (http://www.diychatroom.com/f17/condensation-issues-150668/)
7echo 07-18-2012 07:23 AM
condensation issues
Got condensation on a grill. Room has drop ceiling acoustical tile.
Will it help to insulate the boot really well? If not, any suggestions?
scottmcd9999 07-18-2012 07:36 AM
Yes, you can insulate the boot, and that should be done. However, condensate at the grill face is often caused by low air flow. Check filters, evaporater coils, blower, etc etc to insure they're clean.
techpappy 07-18-2012 09:23 AM
also make sure you have adequate return air to promote air flow
condensation should only occur when system is first turned on then stop once room is cooled down and humidity is lowered
biggles 07-18-2012 12:33 PM
filter and squirrel cage are clean sounds like slow air rolling over the register....make sur fan is hi speed listen in cooling mode...then shut at stat and put to FAN/ON no cool call should be HI
