Condensation Forming In Duct - HVAC - DIY Chatroom Home Improvement Forum
Old 01-11-2011, 04:36 PM   #1
condensation forming in duct
Ok, here's my situation. We used to have a down-draft swamp cooler for our
cooler. About 18 months ago, we installed a new furnace and A/C unit. The
swamp cooler was removed and the duct was capped. It probably sticks out
of the roof about a foot or so. During the original home construction, there
was no return installed on the top floor. When we put the A/C unit in, we
installed a return into the side of the swamp cooler duct in the attic and ran
it down through the chase to the furnace.
With the very cold weather we are currently having, there is condensation
forming on the inside of the duct cap. I have tried putting sheet insulation
in the duct and sealing it with tape to prevent warm air from getting up there
but not having any luck.
Water is dripping out of the return grate onto the carpet.
I would appreciate any help or ideas on this
oneeyedfatman is offline   Reply With Quote
Old 01-11-2011, 05:06 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,838
Spray it with 3M expanding foam sealer used for around doors/windows. Makes a airtight hermetic seal and is impervious to moisture. Won't get wet and rot. Available at HDepot.
Planning on New duct work..any feedback... kilosos2 HVAC 28 01-26-2011 09:21 AM
Metal duct or flex? smokey982 HVAC 6 08-06-2010 06:20 AM
Duct condensation imhotep HVAC 9 02-13-2010 11:46 AM
Wire size for 300watt trans, 3 way 100ft Al the Diy guy Electrical 16 03-22-2008 08:46 PM
Condensation in Wall: Can I Seal a Dryer Duct With Caulk? xquercus HVAC 5 07-01-2007 02:33 PM
