Condensation Of Flat Below - HVAC - DIY Chatroom Home Improvement Forum
Old 08-13-2006, 07:07 PM   #1
condensation of flat below
The ceiling of my flat full of drops of water/condensation and this making wet floor. This situationn is due to the strong air conditioning of the supermarket above our flat. What can I do to prevent the condensation in the ceiling.
loying is offline   Reply With Quote
Old 08-13-2006, 07:21 PM   #2
If this is from the a/c then the drain is plugged. Have the superamrket have it repaired.
If this is a plumbing leak then have it checked before it gets worse.
redline is offline   Reply With Quote
Old 08-15-2006, 08:37 AM   #3
Rewards Points: 150
I believe that the problem is rather temperature difference. The air in flat is warm and humid, and supermarket above is cold. (Living under a supermarket? Yeouch!!!).
Adding some extra insulation would help, but that is a rather destructive process. Though I believe a series of small holes along either market floor or apartment's ceiling would to blow insulation in.
Unless you own the building, getting the supermarket to cool less is highly unlikely.
Best option, IMO:
You could do something about your own air. Put in a dehumidifier to remove excess moisture. It ends up on your ceiling/floor anyway.
scorrpio is offline   Reply With Quote
Bathroom Vent Not Vented to Outside / Would need to vent through flat roof House_Amuck HVAC 5 03-30-2007 09:57 AM
Flat roof - Rolled? - leaks Advice? JJ2001 Roofing/Siding 4 11-19-2006 06:17 AM
Need Help on the Flat Roof and more... MelindaA Roofing/Siding 12 12-21-2005 10:12 PM
Where flat roof meets shingled roof bstyer Roofing/Siding 1 07-07-2005 08:34 PM
Air Conditioner Condensation Issue Unregistered HVAC 1 07-23-2004 02:10 PM
