Condensation Drain Tube Prablem - HVAC - DIY Chatroom Home Improvement Forum
Old 03-07-2009, 11:52 AM   #1
condensation drain tube prablem
This morning we discovered a leak in the basement and traced it to a hole in the plastic condensation drain tube (it looks like a critter knawed its way through the plastic). As a short-term fix, we're thinking of wrapping the damaged section of tubing with duct tape. We're in Atlanta and don't need to keep the HVAC system on right now because the temperature is in the high 60s and 70s. Does anyone have cautions about the safety of using duct tape for a few days?
Fixitwannabee is offline   Reply With Quote
Old 03-07-2009, 11:57 AM   #2
Duct tape will work the tubing is likely 3/8 or you could get a coupling slice the tube and install that
mhoy9 is offline   Reply With Quote
please help with clawfoot tub drain - obselete tube size? wombosi Plumbing 1 01-27-2009 03:26 PM
Air Handler Condensation drain Rickl HVAC 3 11-12-2008 10:27 AM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 04:37 PM
A/C Condensation Drain Sammy HVAC 6 05-13-2007 06:40 PM
