Old 06-24-2009, 10:18 PM   #1
Default condensation coming out of air vent
I've got condensation coming out of my A/C vents. The duct work is in the attic.
Not sure how long this has been going on (it's a rental property) but there is quite a bit at some vents, not so much at others.
Any suggestions on what the cause might be and how to resolve it myself would be appreciated. Money is kinda tight right now and if it's something simple I can fix without calling a service tech would be great.
bmancanfly is offline   Reply With Quote
Old 06-24-2009, 10:34 PM   #2
Master Plumber/Mechanical
Sounds like the duct work is not insulated.
All duct work in an attic needs to be insulated to include the pleum, trunk and branch ducts
Old 06-24-2009, 11:34 PM   #3
If the vents are condensating, you check for an air flow restriction. I'm guessing the filter is blocked. I would start there. It could also be a dirt evaporator coil.
bluefitness is offline   Reply With Quote
Old 06-24-2009, 11:47 PM   #4
If the coil is freezing because of a lack of air flow then normally the complaint from the HO is the house is hot. See freezing not condensating.
Duct in attic..attic hot..no insulation..duct cool...then condensation on/in duct and out of vents..
I have thawed many coils and NEVER a complaint that there is water coming out the vents
Went on a big job the other day where the main trunk went through and office and into the warehouse..Not insulated and when people walked through the door to the warehouse the would be dripped on. Insulated duct problem fixed.
Start with the duct
Old 06-25-2009, 12:09 AM   #5
Start with the duct
I'm not saying that it has gotten to the point that the coil is icing. When the air flow slows down enough, the air coming out of the registers drops the register temperature below the dew point. This causes condensation on the vents. Think about it. If you have a cold glass of water, you will see condensation on the outside of the glass. When air flow is restricted, it will cause the metal of the register to become too cold. What do you get? Condensation. Check your filters before going to deep into it.
Trust me. It will cause condensation.
Old 06-26-2009, 12:55 PM   #6
Well, I went up in the attic and much to my surprise the plenum, and all ducts are well insulated.
Also checked the air filter and it is not clogged, or even particularly dirty.
Old 06-27-2009, 12:09 AM   #7
JohnH1's Avatar
Remove one on the vents that are dripping and see if the boot has a tight fit around the drywall or is there some space were the attic air can mix in. it should be a tight sealed fit.
JohnH1 is offline   Reply With Quote
Old 06-27-2009, 09:49 AM   #8
An old Tradesmen
Yep.
Good chance your drawing attic air in.
Seal the boots to the opening in the ceiling.
More On This Topic
How to Find Total Duct Loss
How to Find Total Duct Loss by Expert Village
Hi! My name is Joshua Lindsey with CFM Building Solutions. On behalf of Expert Village, we are going to do a duct test in this house. Now we are looking for the total loss even the loss to the inside, even the loss where our tape might be leaking or... Read More »
The cumulative total of all heating and air conditioning lost through the average home's air leaks is equal to that lost through an open window. With the costs of electricity on the rise, it has become crucially important to save energy by insulating air... Read More »
How to Pressurize a Room
How to Pressurize a Room by Expert Village
Hi! My name is Joshua Lindsey with CFM Building Science Solutions. On behalf of Expert Village, we are going to do a duct test in this house. Okay right up here above you we have taped off the air conditioning vent into this room. So I want you to think... Read More »
Proper Attic Insulation
Proper Attic Insulation by Expert Village
Hi! My name is Joshua Lindsey with CFM Building Science Solutions. On behalf of Expert Village, we are doing a frame walk and insulation inspection on this home. We talked about earlier how your insulation can become a filter essentially and if it doesn... Read More »
Hi! My name is Joshua Lindsey with CFM Building Science Solutions. On behalf of Expert Village, we are doing a frame walk and insulation inspection on this home. In talking about insulation, one area that we need to cover is how well your house is sealed... Read More »
Condensation accumulating in dryer vent. luckie_reubs HVAC 18 06-03-2009 06:34 PM
Condensation from Ceiling AC Vent meth HVAC 20 04-06-2009 09:49 AM
Water Coming Out of Vent Line?? dost559 Plumbing 3 06-11-2008 10:50 AM
bathroom vent fan - condensation problem jaspar General Discussion 9 01-27-2008 08:46 AM
Help! no air coming from master bedroom vent!!! thomasmona HVAC 3 06-02-2007 11:56 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
