Condensation On Ceiling A/c Vent - HVAC - DIY Chatroom Home Improvement Forum
Old 06-13-2011, 07:01 PM   #1
condensation on ceiling a/c vent
new a/c installed two monthes ago. one small ceiling diffuser in a closet has water droplets forming on it. The other five difusers in the other rooms are fine. In florida at this time the attic is well over 100 degrese, the a/c has flex pipes to each ceiling difuser and at times it seems you can smell the moisture. the old a/c never did this
Bill Melater is offline   Reply With Quote
Old 06-13-2011, 07:20 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 382
Did you get a new airhandler installed with the new AC? Sounds like the fan speed is too high and water moisture is being sucked/thrown off the coil and getting to the grill. Can be a HUGE HUGE problem if it gets into the flex pipes as the insulation will get ruined/wet and become moldy and a health risk. Need to get a Pro to check them out and find the real problem.
Old 06-13-2011, 11:07 PM   #3
Rewards Points: 1,088
Keep the closet open when the AC is running to allow air to circulate. Could be an issue of humid air condensing on the colder surface of the vent.
handy man88 is offline   Reply With Quote
Old 06-13-2011, 11:12 PM   #4
I'm Your Huckleberry
Rewards Points: 2,270
This is most likely the issue.
Doc Holliday is offline   Reply With Quote
bathroom vent fan - condensation problem jaspar General DIY Discussions 16 03-23-2012 10:54 AM
How to attach air duct vent to drywall ceiling dpoplin HVAC 1 06-05-2010 12:55 PM
Ceiling condensation icemand Building & Construction 1 12-15-2009 05:16 AM
Condensation on cathedral ceiling barbaraizac Roofing/Siding 46 09-26-2009 10:48 PM
HVAC Ceiling vent falling off, how to fix? guile Building & Construction 4 01-20-2009 02:44 PM
