Condensation In Air Handler/return Vent / Dripping To Carpet - HVAC - DIY Chatroom Home Improvement Forum
Old 07-31-2013, 08:58 PM   #1
Condensation in air handler/return vent / dripping to carpet
I know very little about hvac topics but hope that I can explain this clearly.
The attached picture shows what I see when I remove the filter from my hvac unit. The unit is heat and air, all electric, no gas...that's all I really know.
As you can see, condensation is dripping from the coil that is visible when the filter is removed. Problem is, the consendation pools and then runs through the opending near the pvc pipe you see. When it runs through, it just drips onto carpet in a closet. So I assume the condensation should not be dripping/pooling, or else it would have some sort of exit path other than my carpet.
Do I need to clean this coil? How? Something else the problem?
Thank you in advance for any help you can offer.
Condensation in air handler/return vent / dripping to carpet-20130731_190430.jpg
impact18 is offline   Reply With Quote
Old 07-31-2013, 10:08 PM   #2
Rewards Points: 146
Could just be your condensation drain line is plugged and it's backing up going onto your carpet. Looks pretty dirty - lot of algea & mold building up.
how to clean indoor coil
how to unplug condensation line
jmon is offline   Reply With Quote
Condensation in the crawl space around AC vent Chandra2012 HVAC 1 09-08-2012 05:41 PM
vent chute condensation chasnygold Roofing/Siding 1 11-28-2010 07:21 PM
Water dripping from vent pipe Rosy_55 Plumbing 4 01-07-2010 10:35 AM
condensation in ac vent filtnib HVAC 2 01-02-2010 09:19 AM
Gaps at baseboards after carpet install cometbus Flooring 9 10-01-2007 08:48 PM
