Condensation - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-26-2010, 07:04 PM   #16
An old Tradesmen
Rewards Points: 6,074
So he didn't record the SH and SC so you could tell us what it was?
Old 06-26-2010, 07:40 PM   #17
I did not think to ask. I do recall a temperature reading of 50 on the refrigerant line. Not sure which one he had the probe connected to though.
aero is offline   Reply With Quote
Old 06-26-2010, 07:54 PM   #18
An old Tradesmen
At 50, it would have been on the vapor line(the large line).
If it was on the small line. You would have a big problem.
SH and SC would tell me more. So will pics.
Old 06-26-2010, 08:09 PM   #19
Just a thought here. The primary condensate drain is the only one hooked up. Would hooking up the secondary help in case there was to much to much condensation ocurring from the evaporator at one time. I tend to think the blower is sucking up some condensate.
Old 06-26-2010, 08:24 PM   #20
An old Tradesmen
Shouldn't be able to suck up any condensate. Unless the velocity through the coil is too high. In which case. It would mean there is an air flow issue.
Old 06-28-2010, 10:55 PM   #21
I think I have found the problem, It is the supply take off starting collars that attach to the plenum in the attic. They were poorly installed and are detached somewhat and leaking conditioned air. I remember telling the tech that at night the plenum showed signs of light frosting but when the sun rises the plenum would sweat badly. He told me that the sun rise should have no bearing on whether it would frost or sweat. In fairness to him he did say he could get his duct guy to look at the ducts. I plan on doing the repair myself and will let you know if it solves the problem.
condensation leak with metal roof on cathedral ceiling in Canada Serialrenovator Roofing/Siding 10 02-02-2010 01:18 AM
Which Gas Hot Water Heater walds11 Plumbing 66 01-16-2010 08:38 AM
Moisture on windows baum Building & Construction 56 12-22-2009 06:39 PM
Condensation on lines leading from compressor mrincon HVAC 5 07-08-2009 08:57 PM
Sweating windows big daddy-o General DIY Discussions 15 01-06-2008 03:41 PM
