Old 08-11-2008, 12:27 PM   #1
Default Condensate pump install question
I wish to install a condensate pump on the ac unit in my basement. It currently has a drain going to a hole in the slab that supposedly lets the condensate disperse into the gravel underneath. Well, this clogged up yesterday and I figure there's got to be a better way.
My issue is what to do with the outlet of the pump? I don't want to go through to the outside with it because I have enough problems with water outside the foundation already and there's no sump pit to go to either. I'd like to run it into a drain pipe if I can.
A quick on the topic search yielded this post:
Originally Posted by Chimichanga31 View Post
A (condensate) pump can be directly tied into sanitary sewer. The check valve in the pump that is holding the water from flowing back into the pump reservoir will do the job of making a seal. Just loop your line coming off the pump to ensure there is a water trap.
I think this will work for me, but how can I tap into the drain pipes in my basement? I have copper drain pipes coming down from the bathrooms and kitchen and they go into a large cast iron drain that runs along my back and side walls and then out to the sewer.
Would I be better off posting this question in the plumbing section?
Any advice would be appreciated. TIA, Kirk.
kboorman is offline   Reply With Quote
Old 08-11-2008, 12:30 PM   #2
Brass or copper......you simply need to find a way to access that pipe. If you cant solder in a fitting, then you should probably call a plumber.
statman is offline   Reply With Quote
Old 08-11-2008, 12:52 PM   #3
I can solder, it's just a pretty big pipe (1 1/4" or so...) and I'm not sure if I could get it hot enough with a regular propane torch to get the job done. Not sure if there's an appropriate fitting in that size with a T or nipple that I can attach the condensate line to either. I'll have to do some more poking around for that.
Old 08-11-2008, 07:49 PM   #4
oops, did I do that!
Do you have a utility sink you could run it to? There are no floor drains in your home?
8 Ball is offline   Reply With Quote
Old 08-12-2008, 08:49 AM   #5
Nope, not one drain in the basement.
I went out last night and got a 1 1/2 x 1 1/2 x 3/4 tee, a 45, a reducer and a hose barb that I'm going to fit into the kitchen sink drain just below the floor joists. That's below the p trap but I'm hoping a loop in the drain line and the check valve in the pump will take care of any sewer gas issue. I got a mapp gas torch because I didn't think the propane torch would work, so I think I'll be good to go.
I'd appreciate any feedback on potential problems with this install so I can avoid headaches with it in the future.
As a side note, don't you love getting into a project and uncovering shoddy work that has to be repaired before you can do your job? When I removed the side panel from the unit last night, I found that there's no provision for securing the filter. There was a filter in there but it was just bent in half and stuffed into the enclosure near the fan.
A while back, I was installing a gas pipe down there and got shocked when I touched the pipe and a duct at the same time. Turns out they ran the t-stat wiring through a hole they punched in the sheetmetal of the heater and never installed a grommet. The metal wore through the wire insulation and viola! 110 v coming from a duct!
Edit: The more I think about it, the t-stat doesn't get 110v. I'll have to do some more poking around to see if anything else is shorted.
More On This Topic
If you live in a part of the country where the temperature gets down below freezing, you just might run into the problem of having your water or drain pipes freeze. As long as you’re home (and not off vacationing somewhere warm) you can usually fix... Read More »
Taking copper pipes apart may be necessary if you're remodeling an older home or if you have a leak between a pipe and a fitting. It's a job the home handyman can handle with the right tools. Just follow the steps below. Read More »
Hi! This is John on behalf of Expert Village. In this video clip, I will show you step 1 for installing a ball valve. I am going to be installing a ball valve on this pipe. This pipe is a hot water pipe, and I know that because when I trace it back, it... Read More »
Hi! This is John on behalf of Expert Village. In this video clip, I will be showing you step 6 of installing a ball valve. I am going to go ahead and show you a few tips for soldering. I am going to solder this ball valve on the ground primarily for the... Read More »
Okay we are here at tub number 2 and we are finishing the drainage system with using PVC pipe. You will notice that I've only drilled holes on one side. The other side of the pipe is intact. We are going to roll the pipe over so that the holes are to the... Read More »
sump pump question THEBIGPUNN General Discussion 0 03-25-2008 03:44 AM
Another sump pump question vavs Plumbing 11 02-14-2008 07:16 PM
HRV install - bathroom fan question jdelisle HVAC 0 01-24-2008 04:41 PM
Sump Pump Question cibula11 Plumbing 9 04-26-2007 05:28 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
