Condensate Pump Help Needed - HVAC - DIY Chatroom Home Improvement Forum
Old 11-11-2011, 10:12 PM   #1
Condensate pump help needed
Hi,
I have a Carrier Weathermaker 9300 TS furnace with a Little Giant 115V condensate pump attached to the side that appears to not be working correctly. The problem started a week or so ago - normally, the reservoir attached to the pump fills up, it flips on, empties out, and turns off automatically, as needed. Now, the pump turns on, but it never turns off - if left like this, I'm sure that the pump would eventually burn itself out.
I'm looking for general ideas on what could be causing this problem - is it a pump issue or a furnace issue? I've already replaced one of the switches inside the pump but it had no affect. As it stands now, if I want heat, I have to manually turn the pump on, empty it out, and then turn it off. Can't afford to call a plumber, just recently laid off of my job.
Thanks in advance, any help would be very much appreciated.
mattsalad is offline   Reply With Quote
Old 11-11-2011, 10:15 PM   #2
Rewards Points: 616
Originally Posted by mattsalad View Post
Hi,
float is sticking, condensate pumps cheap way under $75.00 if its that old replace it
carmon is offline   Reply With Quote
Old 11-11-2011, 10:15 PM   #3
AKA HVACTECHFW
Rewards Points: 1,208
the float is sticking, clean the reservoir and float or replace the pump assembly.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 11-11-2011, 10:57 PM   #4
It doesn't appear to be sticking - details attached.
There are two floats in the pump: one attached to the safety switch assembly, the other to the float arm. I've attached a link to the specific pump with the spare parts list as reference (ref# 6 & 14 in the parts diagram):
http://www.grainger.com/Grainger/rp_...LITTLE%2BGIANT
Both floats appear to be working fine. When the reservoir is full, the switch attached to the float arm turns the pump off. The only way i can get the pump to drain is by forcing the float arm down to turn the pump on, which seems strange since it's floating at the top of the water and i would have expected this to turn it on. Once the water is drained from the reservoir, the pump continues to stay on until I manually pull this float back (I'm wedging a screwdriver in there for now just to keep the pump turned off).
It seems to me that the other switch, the "Safety Switch Assembly", would turn the pump ON after the water rises to the top, but lifting that float manually to turn it on does absolutely nothing.
I hope this makes sense...
Old 11-11-2011, 11:33 PM   #5
AKA HVACTECHFW
yes, get a new pump.
IT IS WHAT IT IS
Old 11-11-2011, 11:53 PM   #6
new pump?
If that's what I need to do, that's what I'll do. For my own knowledge, what do you think is wrong with it?
Old 11-12-2011, 03:58 AM   #7
AKA HVACTECHFW
the switches are sticking. that is the only thing that it can be. The pump is turned on and off by the float switch. The overflow float switch shuts the furnace and a/c off if the pump is not working so that the pump reservoir does not overflow. You very well may have bent one of the float arms and now it is not working properly because the arm is not contacting the switch button.
IT IS WHAT IT IS
Tags
carrier , condensate , heater , pump , weathermaker
Well Pump pressure switch help needed. slabm7 Electrical 20 11-03-2010 05:56 PM
New Drain for HVAC Condensate Pump LoveMyHome Plumbing 6 12-05-2009 06:59 AM
Low Well Pressure, Submersible Well Pump, Help Please! tpolk Plumbing 7 11-13-2009 06:13 PM
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 03:06 PM
Help Needed ... turn on circulation pump when furnace in AC mode? Diranged HVAC 12 06-04-2009 06:33 AM
