There is a rubber tube that runs from the condensate pump up to the humidifier, what happens to that if I get rid of the condensate pump and run the furnace drain into the floor drain?
Originally Posted by yuri
There is something wrong with the condensate pump and its float and check valve. Should only run for about 1 minute and be off for about 4-5 when the furnace is firing.
Whenever the condensate pump runs, it only runs for about 5 seconds. But as I say, in these cycles it does that every 80 seconds or so. Meaning it runs probably seven or eight times during a furnace cycle.
