Condensate Pump - 2 Safety Wires - HVAC - DIY Chatroom Home Improvement Forum
Old 01-02-2016, 07:55 PM   #1
Rewards Points: 2
Condensate pump - 2 safety wires
My old pump didn't have...Do I HAVE to attach these wires to the furnace? If not can I just wire nut them? If so, should I tie the two together and then wire nut or separately wire nut each wire? Thanks for any help...
Aumi2016 is offline   Reply With Quote
Old 01-02-2016, 08:28 PM   #2
An old Tradesmen
Rewards Points: 6,068
You don't even have to wire nut them together. They are the safety float switch wires, and are dry contact wires. So they don't have any voltage in them unless you connect them to something.
The Following User Says Thank You to beenthere For This Useful Post:
supers05 (01-02-2016)
Old 01-02-2016, 10:21 PM   #3
Rewards Points: 2
Thank you for your time!
The Following User Says Thank You to Aumi2016 For This Useful Post:
beenthere (01-03-2016)
Low GPM Sink to Condensate Pump as a Drain knight508 Plumbing 13 01-29-2015 06:58 PM
Insulation rubbed off Submersible Pump Wires 4acres Plumbing 9 01-03-2015 02:13 PM
HVAC Leaking... not condensate pump danrckville HVAC 6 06-21-2012 11:14 AM
Condensate Pump frequency roboboticus HVAC 2 02-22-2011 11:21 PM
condensate pump box code babikes Plumbing 4 06-25-2009 05:04 PM
