Condensate Line Cleaning - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-01-2011, 11:20 AM   #16
Rewards Points: 27
Yea, it's not pretty, but a $10k replacement isn't in the picture right now. I'm assuming 45,000 btu and a 2.5 ton AC are undersized for this 1515 sq ft home? I'm in Sacramento, California. The filter is in the cold air return in the hallway...before the black ducting you see in the first pic above.
Any recommendations you have on improving the existing system would be greatly appreciated.
asimba2 is offline   Reply With Quote
Old 12-01-2011, 11:21 AM   #17
Rewards Points: 27
Old 12-01-2011, 12:15 PM   #18
have you had quotes for new equiptment and duct work?
harleyrider is offline   Reply With Quote
Old 12-01-2011, 12:21 PM   #19
Rewards Points: 27
Yes. Roughly $10k for a new Rudd system and $9k from another company for all new minus the ducting, which they said was done fairly well.
Old 12-01-2011, 03:45 PM   #20
An old Tradesmen
Rewards Points: 7,808
Furnace and A/C are probably ok size wise. Big problem is the return duct attaching directly to the furnace the way it does.
look at that pic. See how basically the entire opening is directly under the blower housing. There isn't enough room there for good air flow. It should have had a plenum installed on the furnace that is the full size of the furnace bottom, and then the flex return installed on the plenum. This would have given it much better air flow. look at the plate the hole is cut into, that is suppose to be removed when the return comes in from that end.
Is that a 14 or a 16" flex duct?
The Following User Says Thank You to beenthere For This Useful Post:
asimba2 (12-01-2011)
Old 12-01-2011, 03:57 PM   #21
Rewards Points: 27
^^ Exactly the kind of input I'm hoping for. Can I buy a new plenum or will I have to construct one out of sheetmetal?
It's probably one of several reasons why the blower doesn't push much air. It might be okay in heating mode but it seems far too weak in cooling mode. I also notice the fan runs at the same speed in both heating and cooling modes, so perhaps I have the option of connecting the cooling mode wire to a different position on the board? This is a Goodman GMP-050-3, which, according to the specs has a 4-speed 1/3hp 10x6 motor.
Old 12-01-2011, 04:02 PM   #22
An old Tradesmen
Have to either make a plenum out of duct board, or have a sheet metal one made, and then wrap it, or have it lined. Wrap is better.
On the control board. You should see terminals marked heat, cooling. See what wires are connected to it. At least I think that model has separate speed terminals on the board.
Old 12-01-2011, 05:44 PM   #23
Rewards Points: 27
This must be what you're referring to. Looks a whole lot more efficient than mine.
Old 12-01-2011, 05:53 PM   #24
An old Tradesmen
Yes, a square to round/or vice versa will get you much better air flow then what you have.
Proper Water and Gas line bonding. John318 Electrical 5 11-16-2011 11:19 AM
Leaking cast iron drain pipes + roots in 4" main line aminus21 Plumbing 5 09-25-2010 10:21 AM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 02:18 PM
electric line and gas line couch potatoe Electrical 17 09-30-2008 10:43 PM
Condensate Line schott HVAC 17 06-02-2008 03:16 PM
