Condensate Leak Around Inducer Motor - HVAC - DIY Chatroom Home Improvement Forum
Old 05-12-2012, 06:32 PM   #1
Greetings...
My 19yo Comfortmaker GUH furnace was leaking water from the bottom of the inducer motor seal. I tightened the screws and the leak stopped. There is water trickling from the condensate drain line, so it's not clogged.
My question then, is the water buildup around the inducer indicative of a larger problem? Or have I already done what needed to be done?
Otherwise, the unit functions as well as it ever has.
Thank you in advance for any insight.
CorwinO is offline   Reply With Quote
Old 05-12-2012, 07:35 PM   #2
how
Rewards Points: 1,104
I think you just tightened up some screws that were a bit loose. The water in the ID assy is normal. If it's building up to where the ID fan cage can touch the water then that's a different issue of plugged drain lines.
Otherwise it's OK.
how is offline   Reply With Quote
The Following User Says Thank You to how For This Useful Post:
CorwinO (05-12-2012)
Old 05-14-2012, 05:23 PM   #3
Rewards Points: 582
yep water in there is normal there is and o ring type gasket in there i think may as how said just snug up on bolts.....maybe some clogged lines????
Old 05-16-2012, 08:15 AM   #4
Craftsman
At 19 years old you need to check those drain lines. There is probably a lot of sediment buildup in them causing a higher level than normal in the induction blower housing.
Superrick is offline   Reply With Quote
Lennox inducer motor bracket mmm97m HVAC 13 11-20-2014 08:12 PM
replace repair fasco inducer motor myronl HVAC 4 11-19-2011 07:59 PM
Inducer motor potential failure robfrey HVAC 6 12-07-2010 07:35 PM
Bang, right before inducer draft motor starts Jan3Sobieski HVAC 1 12-21-2009 04:48 AM
Inducer motor or control circuit? Please help me troubleshoot. averagerob HVAC 1 03-03-2009 01:43 PM
