Old 01-23-2011, 02:39 AM   #1
Condensate draining into sink drain
The primary drain pipe from my AC condenser drains into the drain pipe of my bathroom sink. I've been reading various posts that indicate this is possibly a code violation, or at least a bad idea.
Any thoughts on this?
The condensate drain does not have a p-trap on it, but at least it connects to the sink drain on the side of the sink (see photo), so sewer gasses venting into the AC should not be an issue. However, I have noticed this winter that when my heat is running this sink makes a glurp, glurp, glurp noise.
Photo:
The condensate drain is the black flexible hose coming out of the wall. It attaches to the sink drain above the trap:
fritzycat1 is offline   Reply With Quote
Adding a utility sink in the basement - draining question sbazzle Plumbing 3 04-24-2010 06:59 PM
Finishing basement....sink won't drain jerrydlish Plumbing 1 08-19-2009 09:36 PM
Help: Kitchen sink drain is clogged with grease cips Plumbing 4 08-10-2009 11:11 AM
Sink Drain Stopper Won't Pop Up erclark Plumbing 7 07-11-2009 08:31 AM
How to drain a utility sink that is in basement? Mikey Palmice Plumbing 40 01-28-2008 10:11 PM
