Condensate Drain: Short 90's Or Sweeps? - HVAC - DIY Chatroom Home Improvement Forum
Old 12-29-2010, 06:31 PM   #1
Rewards Points: 95
Condensate Drain: Short 90's or Sweeps?
I have a 40Kbtu condensing furnace, currently no AC. The furnace uses 1/2 materials inside for condensate. I'll be using 3/4" or 1" material to route the drain out into a lightwell (inspector is comfortable with that.)_
Can I uses standard elbows, or do I have to use sanitary sweep type fittings?
Thank you in advance!
mysterylectric is offline   Reply With Quote
Old 12-29-2010, 06:40 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 92
Standard elbows are fine but the drain MUST be in PVC or vinyl tubing or whatever the inspector prefers. No copper or steel or galvanized pipe as the condensate is acidic and will eat them. I use schedule 40 white pvc
Leaking cast iron drain pipes + roots in 4" main line aminus21 Plumbing 5 09-25-2010 10:21 AM
Furnace leak while running AC unit lbartowski HVAC 3 09-18-2009 01:46 PM
Air Conditioner Condensate Drain djchase88 Plumbing 8 08-28-2009 06:32 PM
Wierd Floor Drain "Backup" rawkintrevo Plumbing 9 06-04-2008 07:10 PM
