Old 09-01-2010, 11:34 PM   #1
Condensate Drain Pan Leak
My AHU is located in my attic crawl space and the condensate drain pan has been leaking for some time. I have a bucket to collect water but have to dump it quite often, especially during summer.
We poured water in through the drain and it seems to have flowed through the pipe to the bathroom below. I've tried some treatment tablets and it still seems to leak. Also, there's plastic pipe that drains to the outside of the house that has been dripping water. I guess I can try to use compressed air. Does anyone have any suggestions?
Thanks much!
tbfreeland is offline   Reply With Quote
Tags
condensate drain pan, hvac
Tub drain leak? kcrossley2 Plumbing 3 01-19-2010 12:47 AM
New Drain for HVAC Condensate Pump LoveMyHome Plumbing 6 12-05-2009 07:59 AM
AC Coil Condensate Drain Options zootjeff HVAC 19 12-04-2009 05:19 AM
Drain Leak Causing Slab Problems? Texas Toast Plumbing 1 09-22-2009 10:37 AM
Condensate Overflow Drain Pan sspatriots HVAC 10 03-30-2009 02:19 PM
