Condensate Drain Keeps Plugging Up - HVAC - DIY Chatroom Home Improvement Forum
Old 08-05-2011, 11:46 PM   #1
Rewards Points: 508
Condensate drain keeps plugging up
This summer, the condensate drain on my mini split has started to clog up every few weeks. What can I do to avoid the clogs? What about running a cup of 50/50 bleach-water solution through the drain every month?
benjamincall is offline   Reply With Quote
Old 08-06-2011, 07:06 AM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 380
yes. also hookup a wet type shop vac to the outlet and suck it out. may need to replace the drain hose if it has a thick mold or slime coating inside.
The Following User Says Thank You to yuri For This Useful Post:
benjamincall (08-06-2011)
Condensate draining into sink drain fritzycat1 HVAC 0 01-23-2011 01:39 AM
is it ok to drain condensate to a below slab interior perimeter drain? steveel HVAC 2 12-03-2010 05:20 PM
AC Coil Condensate Drain Options zootjeff HVAC 19 12-04-2009 04:19 AM
Condensate Overflow Drain Pan sspatriots HVAC 10 03-30-2009 01:19 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 03:37 PM
