#1 |
First time home buyer
condensate drain on ac
Is cool air supposed to be blowing out of my condensate drain on my central ac unit where the evaporator coils are?.
I also feel air blowing out of the hole where the freon lines run into the evaporator housing. Both of the above comments are describing the part of my ac that sits just down stream of my furnace. |
#2 | |
condensate drain on acQuote:
#3 |
Union HVAC Tech.
Any holes in the plenum (the box around the coil) should be sealed just as any air leaks in the ductwork. If there is a trap on the condensate line it shouldn't have any openings between the coil and the trap an open vent after the trap isn't a problem.
| Display Modes | |
| Washer drain | peloncito | Appliances | 7 | 08-04-2007 01:56 AM |
| How to outline the 1 1/2" PVC drain | froddan | Plumbing | 6 | 07-24-2007 04:15 AM |
| Food backing into shower drain | Manuel6 | Plumbing | 5 | 11-23-2006 09:59 AM |
| Basement Drain + Carpet | redwards | Plumbing | 1 | 07-21-2006 04:42 PM |
| Need to move a tub drain to line up with a new tub, is it ok to do this... *PICS* | J187 | Plumbing | 6 | 05-23-2006 12:13 AM |
