Old 10-24-2009, 11:37 PM   #1
Default Condensate in draft inducer
Furnace is White Rogers/York LD12N08QA natural gas.
The issue is condensate building up in the draft inducer blower and causing the pressure switch to lock out. When I drain the blower and reset the switch it fires just fine.
I've checked all the hoses and every one is clear. Had a tech come out and look at it and he said that I should try to put a little more drop in the vent pipe as he thought it might be too level or perhaps the draft inducer motor was getting old and losing power. He also suggested running a piece of rubber tubing from the drain on the condensate blower to drain out the water as it filled.
The thing is this furnace has been in use for about 13 years with no condensate problems ever. I'm also pretty sure that electric motors don't lose power as they get older.
Any advice on what to check will be greatly appreciated.
Thanks!
Longhunter1757
longhunter1757 is offline   Reply With Quote
Old 10-25-2009, 12:07 AM   #2
old pro
Carefully check the intake pipe outside and inside where it attaches to the burner box. There may be a screen there. I have had leaves, wasp nest etc get sucked in. If the pipe is 1/2 plugged on some units the burner still fires but the velocity thru the heat exchanger increases. This can cause water to get sucked into the ventor fan from the collector box. Happens with the Lennox G26 and G32s.
Old 10-25-2009, 07:37 PM   #3
yuri,
Checked the pipes, both are clear.
Any other suggestions?
The section of pipe the tech told me to drop is only about 12" long. Will this really cause a problem after not having any for so long?
Thanks!
Longhunter1757
Old 10-25-2009, 07:47 PM   #4
Master Plumber/Mechanical
Look at the inducer and to the mounting surface where the inducer mounts towards the bottom corner you should find a rubber type hose. About 1/2" - 5/8" in size
When you remove the hose you may let the water loose. just clean it up
Sometimes the hose will get a slim build up also check the drain tube. I had a drain line that went 15 ft and a blockage was in the first 90
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Arcoaire and Trane Dealer
Old 10-25-2009, 08:12 PM   #5
old pro
Post some pics of the front of the furnace, draft inducer and drain from the collector box and furnace. The trap may need to be removed if possible and flushed with hot water and javex. Plus what Plumber said.
Old 10-27-2009, 02:05 PM   #6
Going to pull the inducer here as soon as I can.
I'll try to get pics also.
Thanks!!!
Longhunter1757
Old 11-08-2009, 11:46 AM   #7
I Think I got it!
Pulled the blower this morning. Found that when the blower was replaced about 8 years ago the tech used silicone to seal it to the pipe. I removed the sealant and reinstalled the blower and so far (knock on wood) I'm not getting any condenaste in the blower. I'm assuming the silicone had the drain partially blocked, at least that's what I'm hoping.
Thanks for the help gentlemen!!!!!!!!!!!!!!!!!!!
Longhunter1757
More On This Topic
There are many types of furnaces and they all need their filters replaced periodically. Changing your furnace filter can be easy if you know where it is located or it can be downright frustrating if you can't find the thing. Read More »
Hi, I'm Nipa Banerjee from Arts Space India I'm talking on behalf of Expert Village. This is the furnace and this is the door of the furnace, see these are ceramic tiles, this is fiber and these there is 2 coils inside the furnace. After finishing up the... Read More »
Hi! My name is Matthew Christian from Tampa, Florida and on behalf of Expert Village, today I would like to talk about the proper use and maintenance of a leaf blower. The electric leaf blower is very simple to operate. It is just a simple matter of just... Read More »
Hi, this is Jon on behalf of Expert Village in this video clip we'll be changing our furnace filter. Now right before winter I always recommend to people to go ahead and change out their old furnace filter with a new one. On this unit our furnace filter... Read More »
Here we're demonstrating how to change a heater core on a late model Ford Explorer or Mercury Mountaineer. In this step we're going to talk about the proper service procedure for reconnecting your air conditioning lines to the evaporator, and plugging in... Read More »
Pressure Switch, Draft Inducer, Burner Box, Problem majorapus HVAC 7 10-25-2009 08:14 PM
Tempstar pilot not lighting after draft inducer replacement Kdavid HVAC 53 03-27-2009 04:10 PM
New Rheem 90+ is making a strange noise. Draft inducer? shinkansen HVAC 1 01-09-2009 10:38 AM
Draft Inducer question hvachelp HVAC 3 06-17-2008 06:40 PM
Draft Inducer rapid cycling ncbillp HVAC 0 11-25-2007 04:37 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
