Is The Condensate That Comes From My HE Furnace Safe For Plants? - HVAC - DIY Chatroom Home Improvement Forum
Old 03-20-2012, 11:40 AM   #1
Rewards Points: 18
Is the condensate that comes from my HE furnace safe for plants?
I like using distilled water for my plants. Is it just distilled water coming from my furnace or is there nasty contaminates/exhaust in it.
Thanks.
aboekman is offline   Reply With Quote
Old 03-20-2012, 11:43 AM   #2
Rewards Points: 14,000
It's not distilled but will do no harm to your plants. It's condinsation from the air.
Old 03-20-2012, 11:45 AM   #3
Rewards Points: 18
Okay thanks. Aren't condensation and distilled water the same thing?
Old 03-20-2012, 12:03 PM   #4
Rewards Points: 380
HE furnace condensate is not the same as distilled water. It also contains acidic properties due to the combustion process which your plants may not like. It will actually eat away brass fittings on condensate lines etc. so you may want to try it on a plant you don't particularily like very much.
Air conditioning condensate on the other hand would work very nicely.
HVACDave is offline   Reply With Quote
The Following 3 Users Say Thank You to HVACDave For This Useful Post:
aboekman (03-20-2012), ben's plumbing (03-23-2012), plummen (03-21-2012)
Old 03-20-2012, 12:36 PM   #5
REP
HVACDave has it right on this question.
Furnace condensate is acidic.It would be like watering your plant with orange juice or tomato juice.
I do not think they would last too long.
REP is offline   Reply With Quote
The Following 2 Users Say Thank You to REP For This Useful Post:
Old 03-20-2012, 03:12 PM   #6
HE furnace condensate contains carbonic acid, and will, like HVACDave said, eat through brass; so probably not very plant friendly.
hvac benny is offline   Reply With Quote
Old 03-21-2012, 06:37 PM   #7
Just a DIY guy
If condensation is from the air, the answer is yes, the condensate is virtually pure water. Thus, your air conditioning condensate is pretty close to distilled water, because it is simply the water vapor in the air condensing on the cold AC element.
Furnace condensate, however, is produced by the combustion of natural gas (methane), which produces mostly CO2 and water vapor. (CH4 + 2 O2 --> 2 H2O + CO2). The water vapor condenses as the heat is pulled out of the combustion gases (HE furnaces produce lots of condensate because they pull so much heat out of the combustion gases, so less water vapor goes up the flue).
But the water and water vapor has lots of contact with the CO2.
CO2 + H2O --> H2CO3, which is carbonic acid. So furnace condensate has a pH of about 4, roughly the same as soda pop.
M3 Pete is offline   Reply With Quote
Old 03-21-2012, 06:46 PM   #8
Rewards Points: 1,192
Would that be the same about using water from my basement dehumidifier?
bobelectric is offline   Reply With Quote
Old 03-23-2012, 04:57 PM   #9
sktn77a's Avatar
Rewards Points: 392
No, water from a dehumidifier or AC evaporator is pretty much pure distilled water; water from the high efficiency furnace condensate is weak carbonic acid as M3 Pete has so eloquently described.
sktn77a is offline   Reply With Quote
Old 03-23-2012, 06:38 PM   #10
REP
Water from the tap is water that has run over rocks and minerials picking up trace amounts of iron, calcium,lime etc.
Water that is heated to a steam or gas or evaporated into a gas leaves the mineral content behind.When this gas condenses back to a liquid it is free of minerials.This is what distilled water is.
Old 03-23-2012, 07:10 PM   #11
An old Tradesmen
Rewards Points: 7,808
Water from A/C condensate is not as pure as you might think. Think about how dirty the coil can get.
The Following User Says Thank You to beenthere For This Useful Post:
Old 03-23-2012, 07:28 PM   #12
Just a DIY guy
yes, that is distilled water. And water from an A/C unit or electric dehumidifier is essentially the same thing, taking water vapor out of the air (but it might have some dirt in it, as beenthere points out).
But HE furnace condensate is not from water turned to steam. It is one of the combustion products of the natural gas used to power the furnace. Like distilled water, it won't have any minerals in it, but it has a lower pH (acidic) and may have a few other combustion product residuals in it as well (in very minor amounts).
Quote for new furnace. Reasonable? dengle HVAC 16 03-04-2012 07:01 AM
Problem with Lennox Pulse Furnace Wiring to Thermostat scalvin Electrical 4 12-30-2009 07:48 PM
Bryant +80 Gas Furnace won't light tr0910 HVAC 4 01-14-2009 07:11 AM
Olsen BFL 120 Furnace DaleB HVAC 12 12-19-2008 10:42 PM
Gun Safe vs. Floor Joists allen1466 Building & Construction 9 03-03-2006 08:16 AM
