Hello. long story short, my capacitor went out on my ac condencer fan. I replaced the motor and capacitor (with the same spec motor). Turned it on and fan spins wrong way. Am i crazy?
single phase motor
3 uf35 capacitor
thanks in advance. i am at wits end with this ac, heatpump unit.
You have the wires mixed up on the capacitor. Carefully follow the wiring diagram on the unit to sort it out. Some fan motors have a plug you can use to change the rotation but it sounds like the wiring is mixed up on yours.
The device the meter was connected to was a meter base. All meter bases feed from the top, the load is on the bottom. This one was set up as a test.
Very likely that was 480 volts. 208 or 240 will make a nice POP, but 480 is much more spectacular.
Either way, once you see what can happen, you'll likely check your meter a bit more carefully.
Rob
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
