Concrete Slab Heating Ducts - HVAC - DIY Chatroom Home Improvement Forum
Old 02-13-2011, 05:58 PM   #1
Concrete slab heating ducts
I have a house on a slab. Some of the heating vents get very little to no airflow out of them. I have a feeling im going to have to break up concrete to repair this. Anybody have any ideas before I do that? Thanks
mopar383 is offline   Reply With Quote
Old 02-13-2011, 06:01 PM   #2
Experienced
Jackofall1's Avatar
Is this a new condition or something that has always been.
Did you check to see if dampers are open?
Can you get a fish tape pushed through them?
Mark
Old 02-13-2011, 06:06 PM   #3
Ive been in this house 6 years .It seems to be getting worst. I have yet to try to push anything up them.
Old 02-13-2011, 06:08 PM   #4
Experienced
Jackofall1's Avatar
See if you can run a electrician fish tape through and then tie a line on the end of it, then tie a flue brush to the end of the line and drag it through if you can.
You won't be able to do that if there are dampers, and if there is dampers are they open?
Mark
Locating Waste Pipe Under Concrete Slab stubits Plumbing 6 03-10-2010 09:55 PM
Concrete slab to foundation work tntgarv Building & Construction 3 02-28-2010 12:23 PM
How to install conduit in concrete slab mthabault Electrical 4 02-24-2010 10:57 AM
insulating exterior of concrete slab home.. rvegab00 General DIY Discussions 5 10-15-2009 09:26 PM
PVC underneath the floor (concrete slab) massimo Building & Construction 6 11-19-2008 10:37 AM
