Concord Plus 80 Ignitor - HVAC - DIY Chatroom Home Improvement Forum
Old 02-01-2014, 04:27 AM   #1
Mass. Home Inspector
davevalley's Avatar
Send a message via ICQ to davevalley
Concord plus 80 ignitor
Hello experts,
I'm looking all over the web to purchase a flame sensor/spark ignition for a 1997 Concord HVAC unit. This part has three prongs. Two are for the ignitor and the other is the flame sensor, all in one.
Can someone please help me locate this ignitor....please. We're freezing.
I can post a pic if necessary...
davevalley is offline   Reply With Quote
Old 02-01-2014, 04:51 AM   #2
davevalley's Avatar
The sensor/ignitor looks similar to this one.
My only concern is....will it work on my particular furnace if I went and purchased it?
Old 02-01-2014, 06:31 AM   #3
Hvac Pro
yuri's Avatar
Rewards Points: 1,856
No and it may be dangerous. The position of the spark is CRITICAL for it to have proper ignition. you may end up with delayed igniton, flashback of the flame and a small explosion if it is not correct. also your house ins and fire inspector may have a issue with it. what is wrong with it? unless the porcelain is cracked or very black and conducting electricity to ground they last 4ever with careful cleaning with steel wool.
Old 02-01-2014, 12:40 PM   #4
davevalley's Avatar
Yuri,
Thanks for your reply. I know my ignitor is defective because it wasn't sparking at all until I cleaned the 3 dirty prongs. Now it lights more often but it often takes three or four times for the sparks to finally occur and gas to finally light. I'm not sure what else I can do to avoid the issues with lighting.
Old 02-01-2014, 01:55 PM   #5
Hvac Pro
yuri's Avatar
the spark generator (transformer) in the circuit board may be getting weak and producing a poor spark or the prongs are too far apart/not set to the factory specs.
Blower and ignitor won't shut off! johnhay HVAC 8 04-09-2013 11:22 PM
Brand New Concord Furnace Doesn't Work In Cold Weather LeighC HVAC 21 01-07-2013 08:48 PM
Furnace Ignitor Placement hzechiel HVAC 2 11-29-2011 01:07 PM
Weathermaker 9200 Ignitor fails to light Atomic HVAC 5 03-22-2010 11:59 AM
ruud ignitor problems laddy76 HVAC 1 12-11-2009 05:40 PM
