Concord Gas Funace Diagnostic Indicator Flashing 3 Times - HVAC - DIY Chatroom Home Improvement Forum
Old 12-26-2010, 10:50 AM   #1
Exclamation
Concord Gas Funace Diagnostic Indicator Flashing 3 times
My Concord Gas Furnace diagnostic indicator is flashing 3 times which states that the Pressure switch is open. The draft induser spins freely until the motor kicks in. Then it stops like the gears aren't connecting properly. What could be causing this?
JLBox is offline   Reply With Quote
Old 12-26-2010, 11:32 AM   #2
HVAC / Plumbing
no gears in there.. Probably bad bearing.. Replace motor.. If this is 80% faf. Take the vent pipe off and look for obstructions in the housing
kenmac is offline   Reply With Quote
The Following User Says Thank You to kenmac For This Useful Post:
JLBox (12-26-2010)
Old 12-26-2010, 12:53 PM   #3
An old Tradesmen
Rewards Points: 6,870
If it spins freely by hand. There is no obstruction in it.
Tags
concord gas furnace , draft induser , pressure switch
