Concord Furnace Mopdel: Cg80ua075d12a-1 - HVAC - DIY Chatroom Home Improvement Forum
Old 11-30-2011, 09:29 AM   #1
concord furnace Mopdel: cg80ua075d12a-1
how can i get the installation and owner manual
landi is offline   Reply With Quote
Old 11-30-2011, 10:25 AM   #2
http://www.concord-air.com/
harleyrider is offline   Reply With Quote
Old 11-30-2011, 11:13 AM   #3
I have a Concord Heat pump that is Icing over at the condenser. I pulled the two wires off the control board for the defrost control and hooked up a jumper wire to the two terminals. I reconnected the power to the unit and the fan came back on; however, the unit did not go into defrost mode. Any suggestions?
jhicks11 is offline   Reply With Quote
Concord 90 + high efficiency gas furnace ahamerik HVAC 4 09-20-2011 11:35 AM
New Furnace Install AustinPorsche HVAC 1 05-12-2011 11:16 PM
Concord 90 Plus Gas Furnace Problems turby HVAC 4 11-08-2010 08:38 PM
Help! with Concord 80+ gas furnace + T-STAT joryeln HVAC 0 09-16-2009 01:23 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
