Old 12-15-2007, 09:23 AM   #1
Concord furnace
We have a Concord 80% efficient furnace. The furnace will turn on, the fan will run, the glow coil will light, the gas valve opens and the burners light. After 2-3 seconds they shut down. I have already cleaned the sensor with steel wool and even replaced it with a sensor out of an identical furnace that is running. Any ideas of what else I can look at that may be causing the problem?
twest42 is offline   Reply With Quote
Old 12-16-2007, 12:02 PM   #2
Union HVAC Tech.
Concord furnace
Does the wire coming to the flame sensor have a cut or any damage? It does sound as if the control isn't getting current back from the flame rod.
bigMikeB is offline   Reply With Quote
Old 12-17-2007, 01:17 PM   #3
Concord furnace
Thanks. I ended up replacing the sensor and it works now. When I tried the second sensor, it didn't work but a new one did.
Heil Furnace Burner Problem timothyr HVAC 78 01-18-2013 07:49 PM
anyone ever hear of concord furnace? THEBIGPUNN HVAC 16 10-03-2012 12:16 PM
filter in concord 80 plus furnace hyyx632 HVAC 5 12-12-2008 11:21 PM
furnace and or electrical problems tuasoi General Discussion 4 11-29-2007 01:50 PM
Replacing My Furnace, few simple questions compression HVAC 10 02-03-2007 06:00 PM
