-   -   Concord 90 Plus Gas Furnace Problems (http://www.diychatroom.com/f17/concord-90-plus-gas-furnace-problems-82899/)
turby 10-02-2010 05:45 PM
Hello,
i just joined this site.. and i really don't know anything about this furnace but i need some help.
i have a concord 90 plus gas furnace and it won't ignite. the blower turns on but the gas won't ignite. when i look at the box where the gas is coming it it has a flashing yellow light. it is flashing 3 times. when i look at the back of the panel it says something like pressue switch open or something like that i don't remember i have been searching to long for an answer. but anyways.. how do i close it? what can i do in order to get it working.. my wife and 6 month old baby girl are freezing! hahah
beenthere 10-02-2010 06:43 PM
Check the hose running to the pressure switch. And see if it, or the posts are clogged.
Check your vent pipe for obstructions. Check teh condensate drain trap to see if its clogged.
Take your wife an infant to either your parents place, or hers.
hdupuis 11-06-2010 10:16 AM
Same thing
I have the same problem with the same furnace. The code does indicate that the pressure valve is open. The problem that I have root caused is the vent motor / fan assembly is not creating enough vacuum to trip the switch which allows the gas valve to flow gas to the firebox.
It appears that I need to change the vent motor assembly at a cost of $400.00. This motor is also making a high pitched squealing noise as it has a bad bearing. This may be related in my case, however it may not be the same in yours.
Make certain that the vacuum hose and insert to the vent motor are clear. This should at least rule out this issue if not repair your condition.
diyorpay 11-08-2010 06:46 PM
Try www.cshincorporated.com for prices.
Try http://www.fasco.com/pdf/pxx.pdf for matching up a motor by brand. (Substitute some numbers ie. 12 for the xx until you get to Concord. Takes some trial and error.)
hdupuis 11-08-2010 07:38 PM
Thanks!
