Concord 90 + High Efficiency Gas Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 09-20-2011, 08:22 AM   #1
Question
Concord 90 + high efficiency gas furnace
I am hoping someone can help me . When I turned my furnace on , all its doing is blowing cold air . I can hear water running threw but my pilot light won't light . I can't afford an repairman . Any suggestions. Thankyou
ahamerik is offline   Reply With Quote
Old 09-20-2011, 08:45 AM   #2
fabrk8r
fabrk8r's Avatar
If you are hearing water you may have a plugged condensate and the water is sloshing around in the draft inducer fan housing. If this is the case some water may have gotten into the draft inducer air switch (vacuum diaphragm switch).
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 09-20-2011, 08:49 AM   #3
Thankyou , but how do I fix this
Old 09-20-2011, 09:23 AM   #4
fabrk8r
fabrk8r's Avatar
Open the access cover and check to see if the drain hose from the inducer fan is plugged.
You may need a pair of pliers to remove the hose clamp. Have a towel ready because if it's plugged there will be a lot of cruddy water that will drain out.
Old 09-20-2011, 10:35 AM   #5
Concord 90 +
I will try this after work. Thankyou
Gas Furnace Won't Stay Running / Thermostat Set High To Start _scott HVAC 6 03-23-2011 07:27 PM
high efficiency furnace exhaust pointing upward? flyorange HVAC 10 01-07-2011 10:18 PM
High Efficiency furnace water leak drtbk4ever HVAC 10 03-20-2009 11:17 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
High Efficiency furnaces? jetchaser HVAC 3 06-19-2008 07:33 AM
