-   -   Concord 90 + high efficiency gas furnace (http://www.diychatroom.com/f17/concord-90-high-efficiency-gas-furnace-117792/)
ahamerik 09-20-2011 08:22 AM
I am hoping someone can help me . When I turned my furnace on , all its doing is blowing cold air . I can hear water running threw but my pilot light won't light . I can't afford an repairman . Any suggestions. Thankyou
fabrk8r 09-20-2011 08:45 AM
If you are hearing water you may have a plugged condensate and the water is sloshing around in the draft inducer fan housing. If this is the case some water may have gotten into the draft inducer air switch (vacuum diaphragm switch).
ahamerik 09-20-2011 08:49 AM
Thankyou , but how do I fix this
fabrk8r 09-20-2011 09:23 AM
Open the access cover and check to see if the drain hose from the inducer fan is plugged.
You may need a pair of pliers to remove the hose clamp. Have a towel ready because if it's plugged there will be a lot of cruddy water that will drain out.
ahamerik 09-20-2011 10:35 AM
Concord 90 +
I will try this after work. Thankyou
