Concord 80 Plus Furnace Issues - HVAC - Page 3 - DIY Chatroom Home Improvement Forum
Old 10-15-2013, 08:59 PM   #31
Rewards Points: 582
Originally Posted by Angry Snail View Post
The valve is a Honeywell SV9520H, I have video of it above showing the green light. I'll try tapping the relays.
Would a limit switch cause this?
I've unplugged/plugged/jiggled the harness from the valve/inducer several times with no luck.
sorry i see the top of the valve ...is the switch on...don't laugh I worked on one a few yrs back for about 45 min ..only to find the switch on the valve off...ben sr
Old 10-15-2013, 09:04 PM   #32
hehe, yes sir switch is on
I work on computers as a 20 year IT tech, the stuff i've seen..........
Angry Snail is offline   Reply With Quote
The Following User Says Thank You to Angry Snail For This Useful Post:
ben's plumbing (10-15-2013)
Old 10-15-2013, 09:11 PM   #33
Rewards Points: 582
look at this
Old 10-15-2013, 09:16 PM   #34
That's it right there. Shouldn't that inducer motor have power if the other 2 wires in that C3 plug are hot with 120v? Or is there something in that valve or on the board that sends power to the motor?
Am I even on the right track with this inducer motor? Is that the first step in startup sequence? I'm trying to move step by step and see if I can figure this out.
Old 10-15-2013, 09:31 PM   #35
Rewards Points: 582
start up....stat calls for heat...small click that is pullin in relay on board.. inducer starts proves pressure switch, ignitor starts.. gas valve opens.. burnners fire.. flame sensor proves there is flame.. blower comes on warms house shuts down stat...that is the basic set up there are some safety switches involved and a limit ...ben sr
Old 10-15-2013, 09:34 PM   #36
Rewards Points: 582
you could pull the leads off inducer and apply 120 directly to see if inducer will run???ben sr
Old 10-15-2013, 09:34 PM   #37
Bleh, lol, that sounds like the board then? I don't get that click, i've checked for that as well.
Old 10-15-2013, 09:35 PM   #38
I may do that tomorrow, i'll get some alligator clips and give that a try
Old 10-15-2013, 09:40 PM   #39
Rewards Points: 582
if your sure of your voltage checks ....change board...ben sr
Old 10-18-2013, 07:18 PM   #40
Ben - power (118v) comes out of the board and into a 4 way plug at the gas valve, the 2 wires coming from the valve to the inducer motor never has voltage no matter what i've tried.
Is there something on the board that tells the valve to supply those wires with voltage for the inducer motor or does this sound like something is messed up in the smartvalve?
Sorry for the questions, i'm ready to order the board but the OCD in me needs to know how this stuff works when I start messing with it.
Power in from breaker to small light switch on side of furnace. Power from that switch straight to the board, from board into smartvalve (118v), wires supplying inducer never get voltage so inducer never starts....Does the valve need to see something from the board to allow power out of the inducer wires?
Old 10-19-2013, 10:09 AM   #41
Hvac Pro
yuri's Avatar
Rewards Points: 1,848
try this honeywell link there are some pdf files with specs and troubleshooting (installation info). the board is a fan timer board (ST9100, get the number off the sticker on yours) and part of the loop, find its info too.
go products>.residential
https://customer.honeywell.com/en-US/Pages/default.aspx
Old 10-19-2013, 12:52 PM   #42
Rewards Points: 77
There should be two wires going from the inducer motor to the control board. Follow them from the inducer to the board and disconnect these two wires from the board. Put one probe from your meter onto each terminal of the board and turn the furnace on with a call for heat. You should, in less than a minute get a reading of 120 volts on the meter. If you do not, the board is probably bad.
firedawgsatx is offline   Reply With Quote
Old 10-19-2013, 01:32 PM   #43
The 2 wires from the inducer to board actually go from inducer to smartvalve, from smartvalve to control board.
They're in a 4 pin connector that plugs into the smartvalve. I'll snap a pic of it.
Old 10-19-2013, 01:45 PM   #44
Here's the 4 pin connector - it goes into the smartvalve. The white and black wires with dashes go to the inducer motor. The plain black and white wires run down to a 4 pin connector at the board. Those 2 wires have 118v running thru them. The white and black wires with dashes, that go to the inducer - never have power.
Old 10-19-2013, 01:46 PM   #45
An old Tradesmen
Rewards Points: 6,914
Board in vale may have burnt out.
What To Do With My Russian Furnace Real Rock Wall/Fireplace- draft issues. Ellethwyn Concrete, Stone & Masonry 2 07-12-2013 04:33 PM
Nordyne furnace, error code: Pressure switch stuck closed. javagrendel HVAC 21 03-25-2013 01:14 PM
carrier furnace issues FixItIfICan HVAC 8 11-19-2008 06:09 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
Concord furnace twest42 HVAC 2 12-17-2007 12:17 PM
