Concord 80 Plus Furnace Issues - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-15-2013, 06:46 PM   #16
Very dirty and dusty, first time i've ever opened this furnace so i'm going to blow the board off, clean it up a bit and i'll look at it, take pics, etc.....
Ben I really appreciate the help and knowledge that you're giving me. Working on race cars and computers my entire life I can appreciate someones help!
Angry Snail is offline   Reply With Quote
Old 10-15-2013, 06:48 PM   #17
Rewards Points: 582
your very welcome will check back.... go over all the post again and see if you may have missed something...ben sr.....
Old 10-15-2013, 07:09 PM   #18
There's a fuse on the board, wasn't bad but I went ahead and replaced it anyway. Here's what i'm trying to work with
Here's a video of the LED light and what it does when I hold the panel door shut
Old 10-15-2013, 08:36 PM   #19
In the meantime I have just cleaned the flame sensor? along with the ignitor?
Rigged the blower motor into the door safety switch to make sure the blower motor worked - it does.
Nothing has helped. Seems like a signal isn't getting from the board to something - or from that valve with the blinking LED to something.
Board is getting power, that much is certain. I'm not sure it's sending power out to something but I don't know how to verify that.
Old 10-15-2013, 09:01 PM   #20
Rewards Points: 77
First thing I notice is that you don't have any wires from the thermostat connected to your board. Did you remove them for cleaning or there aren't any wires attached? There should be thermostat wires attached in the circled area on the board.
firedawgsatx is offline   Reply With Quote
Old 10-15-2013, 09:07 PM   #21
An old Tradesmen
Rewards Points: 6,148
Use meter and see if you read 24 volts or more from the R terminal to the W terminal on that board with the safety switch closed. If so, then run a jumper wire from the R terminal to the W terminal, and close the door safety switch again, and see if it runs.
Old 10-15-2013, 09:16 PM   #22
Ben had me jump R & W earlier, it didn't help.
The wires for the thermostat were off for that reason.
Voltage between R & C was 27
How do I check voltage to the draft inducer motor? Seems like that thing needs to run in order to move onto the next step in startup?
Old 10-15-2013, 09:37 PM   #23
An old Tradesmen
With the R and W jumpered, you check to see if there is 120 volts on the terminals that the inducer connect to.
Old 10-15-2013, 09:39 PM   #24
Just went down and checked the Honeywell valve, seems it controls the inducer fan. There's a 4 pin plug that gets power from the control board, those 2 wires are getting 118 volts to it. The other 2 wires in that plug assembly go to the wiring harness for the inducer, there's 0 volts in those 2 wires. Is there something inside the valve that tells the inducer motor to turn on?
Is it possible this is a bad valve?
Old 10-15-2013, 09:40 PM   #25
0 volts to the inducer harness while jumpered
Old 10-15-2013, 09:41 PM   #26
An old Tradesmen
Bad inducer relay on the board. Replace the board.
Old 10-15-2013, 09:44 PM   #27
Rewards Points: 582
can we see picture of the valve that has the green light on it ....als jiggle those wires on the smartvalve may be loose....ben sr
The Following User Says Thank You to ben's plumbing For This Useful Post:
beenthere (10-15-2013)
Old 10-15-2013, 09:48 PM   #28
Rewards Points: 582
you can try gently tapping the little black relays on the control board have seen these stick....but would mean still needs replaced...
Old 10-15-2013, 09:54 PM   #29
The valve is a Honeywell SV9520H, I have video of it above showing the green light. I'll try tapping the relays.
Would a limit switch cause this?
I've unplugged/plugged/jiggled the harness from the valve/inducer several times with no luck.
Old 10-15-2013, 09:59 PM   #30
Thanks beenthere - didn't see your post. You think it may be board related then?
The Following User Says Thank You to Angry Snail For This Useful Post:
ben's plumbing (10-15-2013)
What To Do With My Russian Furnace Real Rock Wall/Fireplace- draft issues. Ellethwyn Concrete, Stone & Masonry 2 07-12-2013 05:33 PM
Nordyne furnace, error code: Pressure switch stuck closed. javagrendel HVAC 21 03-25-2013 02:14 PM
carrier furnace issues FixItIfICan HVAC 8 11-19-2008 07:09 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
Concord furnace twest42 HVAC 2 12-17-2007 01:17 PM
