Concord 80 Plus Furnace Issue - HVAC - DIY Chatroom Home Improvement Forum
Old 11-05-2013, 07:44 PM   #1
Similar issue as this post:
Concord 80 Plus furnace issues
ONLY, the inducer DOES come on, but nothing else happens. The led lights are continuously flashing as well.
Any ideas?
TommyBoy is offline   Reply With Quote
Old 11-05-2013, 08:07 PM   #2
Have tried changing batteries in tstat, jumping R to W, (all while pushing in door switch) Checked voltage between R & C on board = 27.4 volts, able to turn on a/c to test blower - works fine. I'm lost...
Old 11-05-2013, 08:25 PM   #3
Rewards Points: 614
after inducer.... air proving switch must make......
carmon is offline   Reply With Quote
Old 11-05-2013, 08:38 PM   #4
Got her fixed. I pulled the hose from the inducer and the pressure switch. The inducer end was clogged with dust. Cleaned it out, put it back together and it worked...
Tags
concord , furnace , heat , hvac
Gas Furnace fails only at night - pressure issue? Ken321 HVAC 5 04-15-2012 08:37 PM
Coleman DGAA mobile home furnace issue baluna HVAC 9 04-07-2012 09:55 AM
Help diag. blower motor issue in Lennox furnace partsace HVAC 12 01-23-2012 03:59 PM
Help! with Concord 80+ gas furnace + T-STAT joryeln HVAC 0 09-16-2009 01:23 PM
Furnace Issue After Sanding Drywall libero99 Drywall & Plaster 8 01-10-2009 10:08 PM
