Old 01-14-2012, 10:11 AM   #1
Concord 80 gas furnace
i have a Concord 80 Plus Gas Furnace that is malfunctioning. It seems to reach room tempature and shuts off. and doesnt restart. I have to manually lower the temp on the thermostat till the thermostat clicks then turn the temp back up and the furnace will start. run for several minute warm the house nicely then shuts off and wont start again.
any thoughts on what might be the problem? the indicator light on the furnace blinks 6 times what ever that means
rnwarington is offline   Reply With Quote
Old 01-14-2012, 10:20 AM   #2
Disabled wood vet
titanoman's Avatar
A sticking thermostat?
titanoman is offline   Reply With Quote
Old 01-14-2012, 10:26 AM   #3
Part of the Clover Leaf
A number of things could be wrong. Sensor, hi-limit lock out..
Need more info . model and serial would help.
A lot of older Concords had a Smart Valve that always failed as you describe.
hvac5646 is offline   Reply With Quote
Old 01-14-2012, 10:33 AM   #4
Model: CG80UA100D14B-1
Serial #: S1601L15777
Old 01-14-2012, 10:48 AM   #5
does this have a pilot type igniter?
Old 01-14-2012, 10:56 AM   #6
And does it have a valve like this?
Concord 90 + high efficiency gas furnace ahamerik HVAC 4 09-20-2011 11:35 AM
New Furnace Install AustinPorsche HVAC 1 05-12-2011 11:16 PM
Concord 90 Plus Gas Furnace Problems turby HVAC 4 11-08-2010 08:38 PM
Help! with Concord 80+ gas furnace + T-STAT joryeln HVAC 0 09-16-2009 01:23 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
