Compressor Wont Kick Back In - HVAC - DIY Chatroom Home Improvement Forum
Old 08-20-2009, 06:38 PM   #1
Question
compressor wont kick back in
I am having a problem with a friend of mine's A/C unit. It has a 17degree temp split but the compressor drops out now & then & wont come back on for a long time. My gauges show that the pressures are not equalizing after it kicks out, to allow the pressure switch to let the compressor restart. There is an expansion valve on the system. She tells me that the entire system was just replaced about 2yrs. ago. Any suggestions??? Its hot here in Houston & she is an elderly woman.
apegasus4u is offline   Reply With Quote
Old 08-20-2009, 06:51 PM   #2
GC/Master Plumber/Mech
Rewards Points: 560
Can you provide pressure, outside temp and amp draw on compressor?
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 08-20-2009, 07:29 PM   #3
Are you a tech?
All units have an expansion valves so what are you getting at?
If the pressures don't equalize and you are sure it is cycling on the press switch it may be restricted or very low on gas.
We need more info to be sure
hvaclover is offline   Reply With Quote
Old 08-20-2009, 07:45 PM   #4
HVAC
Sounds to me like you are dealing with a recip compressor not a scroll. With a recip compressor on a expansion vale you need a hard start kit installed. This compressor will not start until the pressures are almost equal with out a hard start kit.
KAVF is offline   Reply With Quote
Old 08-20-2009, 07:48 PM   #5
It's been in for 2 years. Chances are if were a recip ac has a fixed MD.
mitre saw kick back rcm572 Tools 2 02-04-2009 08:46 AM
Heat Pump set back GEAF HVAC 6 01-26-2009 08:49 AM
Trends in 2009: POPCORN TEXTURE IS BACK! studiobarb Interior Decorating 11 09-02-2008 07:26 PM
central air wont kick in? What have I done HVAC 3 08-14-2006 03:03 PM
Sloping Floor and back half of the house. Help! mikeinfrisco Building & Construction 1 01-22-2005 09:50 AM
