Compressor While Running Heat - HVAC - DIY Chatroom Home Improvement Forum
Old 09-22-2012, 08:35 AM   #1
Compressor while running heat
Kind of a dumb question here.
I have a contactor that is stuck in the open/on position. I've ordered my replacement and in the meantime I am just running the ac as needed. When I turn he air off I switch the inside breaker to the compressor off. That way it doesn't run without the air handler and freeze up.
Its starting to get cold this weekened. If I need to turn the heat on, do I need to make sure the compressor runs with it? It doesn't..does it? Compressor is just for A/C?
This is a small carrier unit. Air handler in the attic, condenser outside, gas heat.
thanks
columbiawifi is offline   Reply With Quote
Old 09-22-2012, 11:39 AM   #2
AKA HVACTECHFW
Rewards Points: 1,208
compressor is just for a/c unless you have a Heat Pump. It does not sound like you have a heat pump though.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Heat pump starts initially but will not come back on to maintain temps johnniebravo HVAC 53 11-22-2011 07:48 PM
Long running furnace hurt heat exchanger? quincy HVAC 6 11-09-2010 06:01 PM
Upgraded to new Hunter model 44860 thermostat and now no emergency heat hlmaint HVAC 0 01-08-2010 01:17 PM
HVAC system heat won't run with standby generator running... PTighe Electrical 70 09-14-2009 05:35 PM
Cracked Heat Exchanger SusanB. HVAC 12 10-14-2008 03:57 PM
